Nest connect after power outage won’t light green
dennis4
Power went out now the nest connect will not go green. It blinks blue and then goes off
GeremiG
Hi @dennis4!
Thank you for posting in the community. I'm sorry to hear that your Nest Connect is not showing the green LED light after a power outage, and it shows you a flashing blue light and then goes off.
To help me find the best solution, I'll need to ask you a few questions:
  • Is your Nest Connect offline in the Nest app?
  • Are you getting any error codes in the Nest app?
  • Is your Nest Connect displaying an LED light blue (slowly pulses once), blue (pulses slowly), or blue (pulses quickly)?
  • Have you performed any troubleshooting steps?
Please keep me posted. I'll be waiting for your response.
Geremi
