Nest x Yale - manual entry
itsmekiara
Hello!
I have the Nest x Yale lock and am now renting my home. I would like to know how I can instruct my renters on manually adding their own codes as they won’t be connecting to WiFi. Is there a link to a pdf that I am able to share with them?
thanks
2 Recommended AnswerS
Lance_L
Hello K,
Thanks for reaching out to the Community. I’d be happy to help you with the Nest x Yale Lock. Let’s check it out.
While there is a PDF file for the Nest x Yale Lock that you can download, it’s only for the Installation Guide. Also, to create a new passcode for someone, you’ll need to add them to your Nest home. Then the Nest app will automatically generate a passcode for them. This requires your lock to be connected to WiFi.
Lance
Lance_L
Hi K,
Thanks for keeping me in the loop. I’m afraid the only time you can manually create a code using the keypad on the lock itself is when you first install and set up your Google Nest × Yale Lock. However, once you connect your lock to the Nest app, you can create and use passcodes that you’ve created with the Nest app.
Here’s a handy guide on how to set or change passcodes for Nest Secure and the Nest × Yale Lock.
It was my pleasure to help. Reach out if you have other questions.
Keep me posted.
Lance
Lance_L
Hello K,
Lance
So there is absolutely no way to manually enter a new code into the keypad?? I have a renter and I wanted it to be used as a manual keypad as they’re not tech savvy and I don’t want to have to deal with potential tech issues. I swore I saw somewhere you can use it in this way and program as well.
thanks for the follow up! 🙂
Lance_L
Hi K,
Keep me posted.
Lance
