3 weeks ago
The Yale has always worked fine. Within the past 2 weeks , I noticed the lock went offline, back online. The history line USED to be blue..and it showed whose code was used. Now the line is Green, and it does not show the activity on the timeline. We used the lock 4 times today alone, and nothing shows that a code was used. I have made sure the Nest Connect is firmly plugged in. I have 4 Nest Cameras that all work fine, along with the Nest Thermostat.
i was hoping to add a screenshot to this email, but I see no option. TIA!
2 weeks ago
Hi @Mimmagee,
Thanks for posting to the community! I understand that for some weeks your Yale Lock has been going offline and your activity timeline has stopped recording lock and unlock events. I also see that your history timeline has changed from blue to green and is no longer displaying activity, even though you’ve used the lock four times. I know how important it is for your devices to function as expected, and I appreciate you double-checking that the Nest Connect is firmly plugged in and that your other devices are working fine. No worries; I am here to help.
To better assist you, I’d like to gather a bit more information:
In addition, please attach a screenshot of the 'Green line' you see in the history. To help, I've included the steps on how to attach a picture or screenshot below:
Keep me updated.
Beula
