09-21-2023 03:03 AM
I’m unable to lock or unlock my door. When I’m able to lock it the lock continuously runs trying to lock. I ended up ripping the batteries out so I can go to work. Anyone had this issue or can shed light on what to do?
thank you in advance.
09-24-2023 08:14 AM
Hi PinkUnico,
Thanks for posting here in the Community forum, and I'm sorry to hear about the situation. I want to check if you are still in need of any help. If so, please follow the steps on this guide in troubleshooting Nest × Yale Lock locking or unlocking problems.
Let us know if that helps.
09-24-2023 08:56 AM
I’m still having the issue. My lock will lock unlock and the lock keeps running eventually telling me deadbolt is stuck when I can manually lock it from inside.
09-24-2023 04:56 PM - edited 09-30-2023 03:30 PM
Uh-oh! Have you tried to factory reset your Nest × Yale Lock? If not, factory reset your Nest × Yale Lock, remove it from the Nest app, and then add it back again.
Let us know how it goes.
09-25-2023 05:14 PM
I tried factory reset multiple times. It finally started to tell me that the deadbolt is stuck but I'm able to manually turn the deadbolt and it works fine.
09-30-2023 03:29 PM
Hey PinkUnico,
Sorry for the late response. I know how it feels when something isn’t working the way it should. Since resetting the lock didn’t fix the issue, the best thing to do now is to contact Yale support for further assistance.
Feel free to reach out if you have other questions in the future.
