09-23-2025 01:28 PM
Just bought a Yale lock from habitat for humanity. Trying to set it up. Trying to add to nest app but get message there's no devices to connect to. Not sure if this is due to it being an older lock or what.
09-27-2025 05:43 PM - edited 09-27-2025 05:44 PM
Hi Calm18,
Thanks for reaching out to the community! I understand you're trying to set up your Yale Lock but the Nest app is giving you the error "no devices to connect to." I'd be glad to help you with this!
To ensure we get you the right troubleshooting steps, I first need to confirm you have the specific Nest × Yale Lock. Since other Yale models look similar but cannot connect to the Nest app, this is a crucial step.
Could you check the lock's keypad for two things?
Juan
09-28-2025 03:59 AM
Thanks for the response. I found that I was not getting a connection to the nest connect. Now I cannot get the keypad to work . See post below
https://www.googlenestcommunity.com/t5/Security/Outside-buttons-do-not-light-up/td-p/748086
