12-08-2024 03:00 PM
When locking from the outside the Yale will physically locked but it will says that the lock is blocked and cannot lock. When locking from the inside the Yale app shows that the door is not locked and if use the app you’ll hear the locking mechanism moving but it will say the door is blocked. What do I do to remedy this?
12-11-2024 04:50 PM
Hi @PurpleLipstick,
Thank you for reaching out and the comprehensive information you've provided. I understand that you are encountering some block issues with your Nest x Yale Lock when you lock from the outside, and when you block inside the Yale app shows that your door is not locked. I'm here to help you and find a solution together.
Please attempt the following steps:
Verify that the lock and unlock command was received.
Note this steps requires the Nest x Yale Lock to be online at the time the command was sent
Please keep me posted and let me know how it goes.
Warm regards,
Jeremy
