a month ago
Hello, good morning.
When I tell Gemini and Google Assistant to turn on two lights at the same time, they all turn on. It used to work fine. Now it doesn't.
a month ago
When using both Google Assistant and Gemini for smart home control, you need to be more specific with Gemini by naming the rooms where lights are located.
For Google Assistant in the same room as your lights, a simple "Hey Google, Light" command works. Check this support article for more tips on voice commands: https://support.google.com/googlenest/answer/7029485
a month ago - last edited a month ago
If you're talking to Google Nest speaker and all the lights and speaker are in the same Room then they should work.
If you're talking to your phone and Gemini then you have to be more specific with naming lights in Rooms.
In the same Room I only need to say "Hey Google, Light" turn lights on and off...
a month ago
4 weeks ago
Hola @Suc1 y @SmartHomeH-TAGS .
Ya se dónde esta el problema y para eso es necesario que os diga que estoy es España eso quiero decir que Gémini para para apagar dos luces lo hace solamente con voz y traves de Google Asistant. [Por qué no tenemos Google Home en la aplicaciones de Gémini todavía] . Cambie el idioma a Gemini a Inglés Estados Unidos y como segundo idioma Español España que tenéis la incorporación de Google Home y funciona perfecto apago las dos luces al mismo tiempo perfectamente. En España no funciona bien por lo dicho .
