03-22-2023 01:40 PM
I have 4 Google Nest Hub Max Smart Speakers and 2 Nest Hub Speakers.
Starting a number of months ago, I no longer have the ability make a call in my house using Hub to Hub (“google-call Master Bedroom Hub” for example.). The hub is able to make the call and connect to the other Hub but the audio and video on each hub freezes. My small screen video looks fine but the larger remote displayed video showing on each hub is completely frozen. This occurs on both Hubs.
I can use my iPhone or iPad to make a call to the hubs and everything works just fine. But the in home-hub to hub calling just freezes.
I am connected using a Netgear Mesh Router and am on a 5g network.
Other functions on the hub work just fine—asking about the weather or playing music for example.
Any suggestions on what I can do to use hub to hub calling?
03-29-2023 06:07 PM
Hi PremierBob,
This is not the experience we want you to have, let me help you. A few questions: were there recent changes made? What type of calls are you trying to make between your Nest Hub Max’s and Nest Hubs? Also, for confirmation, is it about broadcasting or actual calls using duo calling? What is the error message when calling between Nest displays?
It would help a lot if you could do a sequential reboot first:
You can try this command: Say, “Hey Google,“ then “call [display or speaker name]" or "video call [display or speaker name].“
If the issue persists, you can unlink the Google Duo from a Nest display. For instructions on how to unlink the Google Duo app from a Nest display, go to the Set up & manage apps for the Google Assistant Help Center page.
Let me know how it goes.
Dan
03-29-2023 07:10 PM
Dan,
My issue with calling from Hub Max to Hub Max has been going on for a long time. I have tried numerous solutions including the ones that you mention above with no success.
Let me try to explain the issue in more detail. Assuming I have 2 Hubs - Hub Max A and Hub Max B. I can say "hey Google, call hub B" for example. Hub A can see their video while the call is connecting and Hub B can see their video prior to the connection. The calls connect with a frozen and stuttering video with sporadic very short bursts of video and audio. Hub A can see the video that they are sending with no issues and Hub B can see their video with no issues also. The problem is the video that each hub tries to receive is frozen or is extremely choppy with the short video and audio bursts.
If I use my iPad to make the call a Hub using Google Home, everything works just fine and there are no issues with video/audio.
I have even experimented with setting on the router such as changing "Nat Filtering" from "secured" to "open." (I'm not sure if this would have any impact but was simply trying many options.)
Also, I'm not sure if this matters but I have MANY different Google products including Google/Nest cameras, Google/Nest Home Security and Google/Nest Protect for smoke and fire. These products are all installed and work with no issues on the Nest Website and App.
I would appreciate any suggestions or help with this issue.
Thank you,
Bob
04-05-2023 02:53 PM
Hey there PremierBob,
Appreciate the effort. It would seem like a factory reset is needed to revert your Nest Hub Max to its default settings. Redo the setup afterwards. Follow the steps below:
You can reset your devices one by one and tell me how it goes.
Dan
04-06-2023 12:06 PM
Dan, thanks for your help with this issue.
I tried doing all that you suggested...load google home/remove each device/reset each device/set up each device as a new device.
Unfortunately, this did not help and I still have the issue with making a Nest Hub Max call to Nest Hub Max call. Again, the video for each Hub Max freezes for only the "received" video on each device. And the video of what you are sending which is shown on each Hub works perfectly.
Also, calls to a Hub Max or Hub work perfectly when using the Google Home App to make the call.
Any other suggestions would be greatly appreciated.
04-10-2023 05:56 PM
Hi PremierBob,
I understand. Could you send here the firmware version of your Nest Hub Max? Here’s how:
To check the version of your Nest Hub Max:
Keep me posted.
Dan
04-10-2023 06:18 PM
I checked the 4 Nest Hub Max's that I have and all have the following-
Fuchsia Version
9.20221010.3.176
Software Version
50.26.12.493473605
Chromecast Firmware Version
1.67.330920
I also have 3 Nest Hubs but am mainly interested in the option for Nest Hub Max to Nest Hub Max calling
Bob
04-12-2023 01:09 PM
Hi PremierBob,
We appreciate all your efforts. We'd be happy to take a look into this for you. Please fill out this form with all the needed information then let me know once done.
Princess
04-13-2023 12:53 PM
Thank you for your help with this issue Princess. I just filled out the form as you requested.
04-13-2023 01:14 PM
Hi PremierBob,
Thanks — we got your form and we've escalated it over to our higher level of support for further review. Please keep an eye on your inbox as someone will get back in touch with you soon.
Princess
04-13-2023 01:19 PM
Thank you!
04-16-2023 02:23 PM
Our team has already sent further troubleshooting instructions to your email. Let’s continue through that channel. Also, please be advised that this thread will be locked after 24 hours.
Dan
