06-23-2024 01:59 AM
My Nest Hub has a grey screen with G on it today, cannot factory reset as suggested in another post. It will prompt to reset then go back to the grey g screen never changing. I tried unplugging and plugging numerous times and reset multiple times in a row. No change. Switching to other outlets did not work. I used a cord for my boyfriend’s hub which is still working and it did nothing for mine. Apparently this is a known issue?? How do we resolve the tying off this screen?
06-23-2024 08:46 AM
Hade same issue from yeasterday
06-26-2024 04:41 PM
Hi there!
Thanks for posting here in the community. I'm sorry to hear your Google Nest Hub is stuck on Grey G screen. Help's here!
To better understand the situation, I'd like to ask a few questions:
Keep me posted.
Melany
06-27-2024 03:02 AM
Thanks for asking.
I have a nest hub gen 2. No led status
Found a tips of resetting the unit 10 times by pulling the power cable.
It accctually worked and thereafter made a reset/reinstallation
06-27-2024 11:09 AM
Hi @HåkanHv,
Thanks for the follow-up. I appreciate your efforts in taking those steps before.
Could you let me know if your Nest Hub 2nd Gen is working properly or if you're still encountering any errors? That will help me determine the next steps.
Keep me posted.
Melany
