Home hub 2nd generation vs nest hub 2nd generation
Jakub2
Can I ask you what is difference between Google Home hub 2nd generation vs Nest hub 2nd generation? Is there option to use cams as baby cam?
Thank you
Azarco
Hey Jakub2,
Thanks for reaching out — let's check this out for you.
Right now for display we have 1st and 2nd generation Google Nest Hub, both don't have a built-in camera but you can link your smart cameras to it so that you can stream them on the display. On the other hand, we have Google Nest Hub Max that is equipped with a camera that enables experiences such as video calling with Duo, home monitoring with the built-in Nest Cam and more.
Hope this information helps!
Alex
Azarco
Hey Jakub2,
Checking back in to check if the information shared above help. Let me know if you have other questions.
Alex
Azarco
Hi Jakub2,
Just wanted to jump in here to check to make sure that you saw our response. If you have any new issues, updates or just a discussion topic, feel free to start a new thread in the community as I'll be locking this thread in 24 hours.
Kind regards,
Alex
