Max display camera no onger works.
Homeappfails
Camera does not work.
@Homeappfails
Without any specifics, it's hard to offer any suggestions.
You could try contacting Support starting with this link:
Thanks.
The nest hub max is "offline" on my phone home app. The clock on the display works and so does the radio. The camera does not work. "The camera is offline" on my phone screen. It all used to work and is 2 years old.
I suspect Google has broken it and expect me to buy a new one. I rebooted and switched off my other display. I uninstalled the app and reinstalled it. It is connected to my router. It also plays music with Spotify.
It is a bad product with bad software and pages of help don't help.
Dan_A
Hi Homeappfails,
This is not the experience we want you to have, let me help you.
I’ll ask a series of questions to narrow things down along with a little bit of troubleshooting.
  1. Did the built-in Nest Cam work before?
  2. When did the issue start?
  3. What LED lights appear on the Nest Hub Max?
  4. When you try to stream the built-in Nest Cam, do you get error messages from the:
    • Nest Hub Max
    • Home app
    • Nest app
  5. Mandatory: What’s the firmware version of the Nest Hub Max?
  6. What’s the app version of the Home app?
  7. Does the built-in Nest Cam work with the following apps:
    • Nest app
    • Google Meet video calls
  8. In the Home app, check if Home monitoring features are enabled. When enabled, does it turn off by itself?
Thanks for helping, MplsCustomer.
Dan
Dan_A
Dan
Juni
Hello there,
Juni
