Mini Won't Connect to WiFi
einsteigenbitte
Hi Community,
I had been using my Google Nest Mini for 3 years without any problems. But I moved last month, and since then I haven't been able to connect it to the WiFi at my new place. I've tried everything - reset mini, reset router, set mini back to factory settings, reset mini AND router at the same time. What gives?
Appreciate your help!
Muddi
Hey einsteigenbitte,
I know how it feels when you can't connect your Google Nest Mini to your new network. Let's try to get to the bottom of this. A few questions: how far is your Nest Mini from the router? Are you using a dual-band router?
To eliminate network issues, please try setting up your device using a mobile hotspot. Please note that you will need two mobile devices for this setup (one will serve as a router and the other to be used to set up your Nest Mini).
Let me know how it goes.
Muddi
Princesss
Hello einsteigenbitte,
Just one quick final follow up since activity has slowed down. We'll be locking the thread in the next 24 hours, but if you still need help, I would be happy to keep it open. If there's more we can do, just let me know.
Princess
Princesss
Princess
