01-10-2022 01:26 PM
We got all our cameras working and connected to the Hub max but cannot get the camera to work on the display. It stays offline. We removed the device and started over and still not working. We don’t want to have to remove all cameras and doorbell and start over. This is obviously a common problem. Any suggestions?
01-10-2022 03:26 PM
Some customers have reported that they have been able to get past the "assisting device" or other problems in setting up new cameras by temporarily turning off their other Nest cameras or devices from within the Google Nest app or the Google Home app, performing the setup, and then turning the other devices back on.
We haven't encountered the problem, so I don't know whether this will work for you, but it's the least disruptive option I've seen reported.
01-10-2022 08:56 PM
I am having the same issue. I have tried to factory reset, Uninstall & Install Google Home and Nest app but nothing worked. Let me know if you find any solution.
01-22-2022 05:19 PM
Same here. I'm dumbfounded. Its like the camera is unplugged, but how can that be?
01-22-2022 05:52 PM
You've followed the "Set up Nest Cam" instructions for the Nest Hub Max? That's what we used for ours.
https://support.google.com/googlenest/answer/9449420?hl=en&co=GENIE.Platform%3DAndroid
04-26-2022 11:17 AM
Thanks for visiting the Community. Since this thread hasn't had activity in a while, we're going to close it to keep content fresh.
We hope you were able to get the help you need, but if you're still having trouble, please feel free to submit another post, and provide as many details as possible so that others can lend a hand. Hope this helps!
