NEST HUB MAX SCREEN BROKEN - NEED REPLACEMENT
TVOO
I need help replacing the broken screen on my HUB MAX. The screen is functioning but the glass is cracked.
I appreciate any help you can provide.
JillG
Hello @TVOO
For out of warranty fixes see this help link: Get a Google Nest display replaced out of warranty - Help
Hope that gets the help you need and your screen all fixed!
TVOO
Thank you JillG,
I tried YouBreakIFix but they either don't have the replacement screen or don't even know anything about the product...
JillG
That's annoying! They are the only link I have for repair. Possibly, contact them via this link: https://www.ubreakifix.com/contact
