Need PHONE calls, not duo.
MartinoHesse
Hi!
I have Hub 2 and nest audio. I need an option to say "OK google, call Veronica" and that the phone start calling Verónica. Currently, when the hub 2 or nest audio listen my command they just keep telling me that my contact doesn't have duo and I should invite her to join. That's really frustrating because nobody in Mexico is interested in installing a complete app just to receive my phone calls.
I have tried but can't find a way to make the hub and nest stop all his letany of "the need to install duo etc etc" and simply start calling my contact with a phone call using the smartphone.
Is that possible?
10 REPLIES 10
@MartinoHesse
The "carrier calling" section on the page below describes the available option for making calls from your Nest speaker:
https://support.google.com/googlenest/answer/9849261?hl=en
Hi! Thanks for replying.
So the carrier calling is only available for that list of countries and carriers?
@MartinoHesse
I don't know; I was just sharing what I could find. You could try contacting Support starting with the link below if you need a more definitive answer.
Dan_A
Thanks again for helping here, @MplsCustomer. @MartinoHesse, I hope you've got the answer you're looking for. Especially with the country's availability about carrier calling. Also, the Google Duo app is needed on both sides for you to be able to reach each other. You can refer to the link above for more detailed info and options on how to use our calling feature.
If you're still in need of any assistance, feel free to let us know.
Dan
Dan_A
Dan
Dan_A
Hi MartinoHesse,
Dan
Thanks for replying. I just wish it could be possible to make phone calls without depending of local carriers. I understand it's not possible but hope this feature to be implemented in the future.
Dan_A
I understand. Including carrier calling, here are the features you can choose from if you want to use your Nest devices for calls: Duo Calling, Google-supported calls, Carrier calling.
Hope this helps.
Dan
