2 weeks ago
I have a Nest Hub Max which was used at our prior home.
I went to set it up at our new place (factory reset) on the Home app and it goes through the process until, at the end, it comes back with "This Nest Hub Max is connected to another account or home". Well, that's me... I failed to individually remove all prior devices from the old home structure before I pulled the plug on the entire home. I no longer have access to that home - as far as I know!
How can I go about getting that prior association cleared from this device??
It will work as a simple assistant - but no camera. Though, when I do ask a question, not only does it reply, but one in a nearby room does too... like they're unaware of each others presence.
THANKS
2 weeks ago
Have you done a factory reset on your Nest Hub Max to clear the account and Wi-Fi settings? You can't do it from within the Google Home app.
https://support.google.com/googlenest/answer/7073477
2 weeks ago
Yes, I mentioned that in the first sentence. But, thanks.
2 weeks ago
Did you hold down both volume buttons on your Nest Hub Max for at least 10 seconds and did the Nest Hub Max let you know that it was resetting?
2 weeks ago
Yes, that's the process for factory resetting. Which was completed, twice!
2 weeks ago
You could try contacting Support:
2 weeks ago - last edited 2 weeks ago
I have not had good experience in the past with Google support. That doesn't mean that there are not people that have the answer to this, but some random person will probably get it, try a half-hearted approach, and then bury it. Hopefully somebody with prior experience with this problem can post a solution on here.
2 weeks ago
Well, you're right that you're supposed to remove the device from the Google Home app while still on your old Wi-Fi network, but the factory reset supposedly overrides that need. If it were mine, I'd try holding down both volume buttons for a longer time, just in case the factory resets you tried didn't actually complete.
