09-09-2022 12:26 AM
Hello, how are you?
Since yesterday I am having problems with my second generation Nest Hub.
Every few minutes it is saying something like "I don't know but these are the search results" and opens the google.com page. It does this even with the microphone turned off.
It also does it with voice commands. If I ask "what time is it" it says "I don't know but these are the search results" and shows me a google search asking for the time. The same thing happens with Youtube and Spotify.
I have already restarted it several times and I have also put the factory settings and nothing, no solution.
Thanks!
09-11-2022 02:54 PM
I know how it feels when something isn’t working the way it should, this is related to a similar trending issue. Our team is aware of this and is already looking into it. You can also try switching the language to English then back to your language and see if that works. Here's how: https://goo.gle/3xh82Lg
Keep me posted.
Nikki
09-09-2022 10:57 AM
Please keep us informed for a definitive solution
09-09-2022 11:11 AM
Same issue here…
09-09-2022 11:29 AM
I do love Google Assistant, but their Hubs are just so tricky, I used to have 5 Hubs and 3 of them died after an Update, they are already out of warranty and Google doesn't want to provide the Fushisa (or at least their first Android) ROM, and now this server-side issues, I'm thinking about my Google permanency 😞
09-09-2022 12:21 PM
Same problem
09-09-2022 01:00 PM
same problem for me since yesterday
09-09-2022 01:03 PM
Mismo problema desde ayer a la noche en Argentina. Ya reinicie el equipo, lo reseteé y pasa lo mismo. Nada funciona
09-09-2022 02:42 PM
It seems something related to language. Setting to English works fine. Waiting for an answer from support
09-09-2022 03:13 PM
Same here in Spain i have reset the device so many times and nothing change it responses to me the hell "i dont know but etc."
Estoy desesperado a ver cuándo lo arreglan jdr
09-09-2022 11:39 PM
I tested in Germany just some moments ago and reconnected my hubs to the power line. It seems to work properly now.... hope that the finally fixed
09-10-2022 02:16 AM
It seems that the problem has been solved since this morning. Try using your devices and let us know.
09-10-2022 09:13 AM
Correct, the problem stopped since Yesterday... 😄
09-10-2022 05:17 AM
The issue has been resolved for me as well! 👍
09-10-2022 05:23 AM
Resolved
09-10-2022 05:53 AM
Hello...from Paraguay...my Hubs are working well now !!
09-10-2022 09:07 AM
Seems to be fixed. 👍
09-10-2022 09:10 AM
Also from Italy, seems fixed 🙂
09-10-2022 09:18 AM
Desde hoy a la mañana ya funciona en idioma español !!!!
09-14-2022 01:16 PM
It's back.
Worse than before actually
09-14-2022 01:23 PM
And we're still here with the exact same problem, Google but what the hell are you doing?
09-14-2022 01:44 PM
Here from Italy too guys! Also my best hub started with the "I don't know..." issue! Actually yesterday at night it was half Spanish and half Italian! Please Google solve this issue!
09-14-2022 02:37 PM
Unfortunately I found the forum too late. We had a power outage last week and the problems started after that. So I thought, **bleep** the power failure has disassembled the Microphone of the Gen. 1 or something similar. Since also a reset has not helped anything. So the opportunity of the Google birthday used and bought a new device, which arrived today.
Initially it also worked without problems, but now the new device also has this problem. Now I know, the change of language would have probably at least solved the annoying. But currently the problem is on both devices after resetting the language to German again.
Any ideas @Mlabrador ?
09-14-2022 08:52 PM
Efectivamente el día de hoy regresó el problema y sólo afecta a mis Google nest hub el Google mini funciona bien. Ya reinicié los 2 Google nest hub, incluso restablecer de fábrica y siguen los 2 igual, el idioma configurado es español y estoy en México. ¿Alguna solución por parte del equipo de Google‽
09-14-2022 11:44 PM
Se solucionó el fin de semana pasado, pero ayer volvió a fallar. Por favor no podemos estar así. Solucionen esto ya.
09-15-2022 05:14 AM
You can partially solve this issue by setting English US as primary language and your native language as secondary in the google home app. Nest hub’s interface will be in English but you can use voice commands in your native language
