06-04-2025 10:33 AM
I had to do factory reset, went through the complete set as new, now my nest hub max show unsigned in the nest app, I can see live steams, but when I try to resign I scan the QR code then as it start setting it says something went wrong, any idea.
Thanks
06-08-2025 04:15 PM
Hi delboybazzer,
Thanks for posting in the community. I understand you're encountering an error when trying to set up your Google Nest Hub Max in the Nest app after a factory reset. I appreciate all the efforts you've made to resolve this. I'm here to help!
To complete the setup of your Google Nest Hub Max, you'll need to link it using the Google Home app. Refer to this article: Set up your Google Nest Hub Max.
Let me know how it goes.
Melany
