New Nest Hub Max - can't complete tutorial - swiping from right edge does nothing
itm
I'm just setting up a new Nest Hub Max, and tried to watch the tutorial, but it won't get part the bit where you have to swipe left from the right side of the screen. I've tried swiping countless times, but nothing happens, and I can't move on to the next stage in the tutorial.
Any ideas??
14 REPLIES 14
listairee
Hello @itm,
Thanks for reaching out. I'm sorry to hear you are experiencing this issue. Have you tried factory resetting the device? Here's a step-by-step guide to help you get started if you have not.
Hope that helps! 🙂
itm
TBH I'm not sure it's worth the trouble of a factory reset - I'd only just taken it out of its shrink-wrap when I hit the problem. It would be annoying to go through the whole setup process again, only to get the same problem.
@itm
You could also try a simple reboot, which does not erase any settings.  You can do so from within the Google Home app, or you can unplug your Nest Hub Max for a minute.
itm
Thanks for the suggestion. I just power cycled it, but I don't see any option to replay the tutorial. It looks like it may only be available after a factory reset.
Muddi
Hi itm,
Thanks for sharing details about the issue. I appreciate  and  for helping here.
I know how it feels not having a working device when needed. To help us get a better picture of what's happening, do you mind sharing a video? Follow the steps below to know-how:
  1. Hit reply or Start a new post.
  2. Click Insert Image.
  3. Choose an image source location.
  4. Follow the on-screen instructions. Also, you can tap the "Drag and Drop" option. Please note that maximum attachment is 5 MB.
Muddi
itm
Sure - what exactly do you want to see a video of?
Muddi
Hey itm,
Please share a video showing the issue on your device so we can check it further.
Muddi
itm
I'm not sure which video would demonstrate "the issue" - I can no longer access the tutorial, so have no way of starting it?
Muddi
Hi itm,
Could you tell us the status of your device now? Is it working?
Muddi
itm
Yes it's working normally. I just never got to see the introductory tutorial, and I don't see an option anywhere to access it.
Hello @itm,
If it is working normally now, it means the power cycle fixed the frozen screen issue.
If you need more information about what you can do on your Google Nest device, you can refer to this link.
Hope that helps! 🙂
Princesss
Hi itm,
Thanks for confirming. Usually, tutorials are shown during the set up process. Here's a link to what is included on the tutorial: https://goo.gle/3QnNxUK
Let us know if you have additional questions and I'd be glad to answer it for you.
By the way, thanks for chiming in @listairee.
Princess
Princesss
Chiming in to see if you still need assistance with this. Hope the previous post helped. Let us know if you have additional questions, otherwise we’ll be locking the thread.
Princess
Muddi
Just one quick final check in here since activity has slowed down. We'll be locking the thread in the next 24 hours, but if you still need assistance, feel free to start a new thread in the community and we’ll be happy to help.
Muddi
