11-28-2022 06:24 AM
About a week ago my Nest Hub Max just powered off. I cannot get it to power back on. I've even purchased a new power supply and that doesn't help.
Is there a quick fix that I don't know about?
11-28-2022 11:02 PM
A “No power” alert can be caused by the following: The thermostat wiring is incorrect. Your thermostat is connected to a system that requires a C or common wire, but that wire isn't connected. Some systems, including heat-only, cool-only, zone-controlled, and heat pump systems, require a C wire or Nest Power Connector.
James
12-01-2022 03:49 PM
Hey Wile_E3,
Thanks for posting.
It seems like you have an open thread with the same issue. We're waiting for you to update us if you have the chance to fill out the form.
Thanks for trying to help, Johnharper1!
Alex
12-05-2022 03:25 PM
Hello there,
It seems like your other thread was closed due to inactivity. Do you still need help with your Google Nest Hub Max?
Alex
12-06-2022 03:27 PM
Hi Wile_E3,
Alex
