Timer won’t audibly ring
ClarkFam7
My google nest will set a timer but when timer goes off, no sound comes out.  I have checked the volume prior to timer and it’s on loudly.  It’s been unplugged and plugged in many times with same result. Thanks.
11 REPLIES 11
Cathal_S
Hi ClarkFam7,
Have you also checked the device settings for alarms and timers volume?
  2. Touch and hold your device's tile.
  3. At the top right, tap settings ⚙️
  4. Then select 'Audio' > 'Alarms and timers'.
  5. Adjust the volume slider.
Cathal
I have tried that multiple times and I adjust the volume to 8, 9 or 10 even and no sound comes out when my timer goes off
Princesss
Chiming in to check if you still need help with this? Hope the previous post answered your question, otherwise I’ll be locking the thread.
Princess
Princesss
I haven’t heard from you, so I’ll be locking the thread in 24 hours. Thanks for posting!
Princess
Muddi
Hey ClarkFam7,
Apologize for the delays. Chiming in to ensure everything is covered here. Just to add have you tried resetting your device to see if it will have the same behavior? Also, could you tell us the what specific Google Home/Nest device are you having an issue with?
@Cathal_S: Appreciate your help here.
Muddi
pinklady
I have a Google Nest Hub and it has the same issue, timers won't audibly ring, despite volume being adjusted. Are you able to share how this issue was resolve please. Thank you.
Muddi
Hello pinklady,
Sorry to hear that you're having issues with your Google Nest Hub. A few questions: when did the issue start? Is there a sound for alarms? How about when you're playing music?
Let's go ahead and reset your Google Nest Hub by pressing and holding both volume buttons together, at the back of the Nest Hub, for about 10 seconds. You'll hear your Google Assistant confirm that it's resetting the Nest Hub.
Let me know how it goes.
Muddi
pinklady
Thanks, Muddi.
The sounds were find with alarms and music, it was just the timer which had  no sound. Resetting it has resolved the issue. Thanks so much 😊.
Princesss
Chiming in to see if you still need assistance with this. Hope the previous post helped. Let us know if you have additional questions, otherwise we’ll be locking the thread.
Princess
Thank you Princess. The issue has been resolved by resetting the device. You may lock the thread.
Princesss
Hi pinklady,
That's good news! Glad to know that everything is all sorted now.
Since this has been resolved, we'll consider this complete and will lock the thread now. Feel free to start a new one if you need assistance with your Google Nest speakers and the Community would gladly lend a hand.
Princess
