01-21-2025 09:46 AM
On 8/24/23, "Princess" posted the following in response to my complaint about the white noise fading out/in every hour and the discontinuation of "help me sleep". I have since asked several times when the issue will be resolved and have received NO response. The fade out/in is unacceptable as it wakes me up - totally defeating the purpose of white noise. My Nest Hub is now just a glorified clock - and I'm not getting what I paid for.
Hello folks,
We've heard feedback that turning off sleep sounds after 1 hour was insufficient for some of our users, so we made the decision to remove the end time. We're currently investigating ways to build a comparable solution and appreciate your patience.
Princess
01-27-2025 01:22 PM - edited 01-27-2025 04:52 PM
Hi macleod0722,
Thank you for reaching out to the community. I'm sorry to hear that your Nest Hub is not working as expected with the White Noise fading out/in every hour and the discontinuation of Help Me Sleep. I'm happy to assist you right now.
Reading the previous case you sent me as a reference, I see we suggest some steps. Can you please confirm if you do the troubleshooting steps listed below?
Any additional details you can provide will be helpful.
Gabriela
01-27-2025 03:43 PM
Are you suggesting that the fade out/in every hour will stop if I do those things? Do you even know what I'm referring to?
The app "Help me Sleep" was discontinued (as a Google partner) in June 2023. The command may work to get white noise. But you get the same fade out/in as you get if you just simply ask Google to "play white noise for 10 hours" ... there is NO difference. The fade out/in was NOT happening when Google was working with "help me sleep". Every hour from when it starts, it fades out to nothing and then fades in again (over a 20-30 second period). I have found numerous complaints in this forum and other places and NO solution - even though, as you can see by Princess' response, Google has promised a solution.
To answer your questions ... Yes, I have done ALL of those things over the last 18 months. Some of them multiple times. I just did many of them again - and I'm still getting the fade out/in.
01-27-2025 04:55 PM
Hi macleod0722,
Thank you for your reply. I appreciate your time doing all the troubleshooting steps. My team would like to know more about this behavior. When you get a chance, please fill out this form. Remember to include the link to this post. Let me know when you’re finished. From there, we'll contact you via email.
Let me know when you're finished. Your confirmation is crucial to ensuring that I can follow up on your case effectively.
Gabriela
