Friday
Copied from https://www.googlenestcommunity.com/t5/Streaming/ADB-over-Network-is-blocked-on-a-wired-connection/m... because it was closed and locked with zero responses.
Aside from the issues that seem common so far, I was also able to spot another problem in regards to the updated Wireless Debugging options.
If the device is connected to the network over an Ethernet connection, trying to select "Enabled" in the settings toggles immediately back to disabled.
However, if I unplug the Ethernet cable from the adapter, wait for the Chromecast to go online over WiFi, and then enable the option again, I'm able to get to the pairing mode activity.
Then, if I don't exit the screen with the pairing port and code before plugging the Ethernet cable again, the device recognizes the change in connectivity and replaces the name on the screen to reflect that, but as soon as I exit this screen again, it forcefully disables Wireless Debugging and closes any connection I was still active on while on the pairing menu.
This behavior remains constant even after a factory reset, and while I'd love to provide logs, the nature of this issue makes it a bit difficult to gather them beforehand, so any help would be appreciated.
This is a significant regression and is unacceptable. Every single google product I own seems to degrade and decay with time.
yesterday - last edited yesterday
Hi @gooworsewithage,
Thanks for reaching out to the community. I understand you're encountering a problem with wireless debugging on a Chromecast device when using an Ethernet connection. I know this may be frustrating, and I appreciate the troubleshooting steps you tried and also you providing a detailed description of your issue. I'm happy to assist.
To gather the necessary information, please answer the following questions:
I'll be waiting for your reply.
Best regards.
Derick.
