02-10-2026 07:22 PM - edited 02-10-2026 07:23 PM
I am having intermittent audio failure issue and only a hard power cycle fixes the issues. I've narrowed the issues down to the Google TV box. The issue happens daily after the turn off the Android TV box more then 4x.
Google TV Device: Onn 4K TV Box
Operating System: Android TV 12
Build Number: SGZ3.231226.086.A1
TV Model: TCL
Audio Device: Onn Soundbar
Connection Setup: Onn 4K TV Box connected via HDMI to the TV. Sound bar connected to tv via HDMI arc.
The Google TV device intermittently stops outputting audio over HDMI. When this occurs:
The only reliable way to restore audio is to physically disconnect power from the Onn 4K TV box and reconnect it. Restarting the device through the system menu does not resolve the issue.
This issue significantly affects usability, as it requires physically disconnecting power from the device whenever audio stops working.
I believe this may be a hardware issue with the android TV box but I'm open to trying other things.
02-10-2026 10:53 PM
I have kind of the same issue. Although I am set up with OMNI860
02-13-2026 04:02 PM
Hi @GP1234567891234,
Thank you for posting in the community. I understand your experience with the audio failure you're experiencing with your Onn 4K TV Box. I know that you’ve already done extensive troubleshooting, including testing the HDMI-CEC and ARC settings, as well as confirming that the issue only resolves when the device is power cycled. I appreciate the troubleshooting efforts and the detailed information you've shared so far. I'd like to share more information with you.
While this community focuses on supporting Google Nest products, we can't directly assist with Onn devices. However, the Onn support is a great resource for troubleshooting Onn devices. They'll be able to provide specific help for the issue you're facing.
Of course, if you have any questions about your Google Nest products, feel free to ask away in this community! We're here to help.
Daniel
