11-27-2024 04:41 PM - edited 11-27-2024 04:51 PM
Hi, it would be awesome if for the Power Button we can check or select to power on the chromecast and send one IR command, my use case it's the following: I have a sound bar connected using Optical cable and I need to turn it on/off using IR. But if I select that sound bar IR option in the chromecast config screen, the chromecast is not turning on/off (and my TV is not turning on/off, either). So I am proposing to add some sort of checkbox in the Power Button configuration screen to turn on/off Chromecast devices besides of the selected IR/CEC option)
It would be awesome if Google can take a look at it!
This is the screen that I am taking about
This applies for Chromecast with Google TV HD/4K and the brand new Google TV Streamer
12-01-2024 04:32 PM - edited 12-01-2024 04:41 PM
Hi @gvillo,
Thank you for reaching out and the comprehensive information you've provided. I really appreciate the information you gave and the recommendation for the power remote button. Please consider sharing your thoughts directly with our development team through this feedback. Your input will help us prioritize features and ensure that we're meeting the needs of our diverse user base.
Warm regards,
Jeremy.
