Chromecast 4K TV does not work with Denon x6700h
pipibjc
I connect the Google chromecast 4K TV to the hdmi1 input port (CBL/SAT) of my Denon receiver X6700h, however, there is no video nor audio output from the hdmi output port.
I tried to connect the same Google chromecast 4k tv to my projector hdmi port  directly, and I can see outputs.
Is there any special setup I should do when connecting to Denon receiver? Thanks!
Kimy
Hi pipibjc,
Thanks for posting here in the Google Nest Community. Based on your description, it seems that there’s nothing wrong with your Chromecast device, as it worked on another device (your projector). I suggest that you switch between HDMI ports. Also, try different cables for output.
I hope it helps. Let us know if you still have questions.
Kimy
