08-16-2023 06:16 AM
Xfinity stream will recognize the pioneer tv but won’t start playing. It used to work. Can u help
08-21-2023 02:12 PM
is it similar to this problem ? Several users are seeing the one described in the thread below:
08-22-2023 03:47 PM
Thanks for sharing, @Bobf123.
@Psocolow, are you experiencing issues loading the contents as you try to cast your Xfinity Streaming app? And all other apps work fine, but the Xfinity Streaming app would initiate the cast but won’t play at all. If yes, then it is related to this thread that was also shared above. Let me know so we can merge the threads or give us more details if they're not related. I look forward to your response.
Kimy
