Connection problem under configuration
Simen2360
When I try to setup my chromecast and I try to log in to wifi, the message "connection problem under configuration, lost contact with chromecast" pops up. I have tried a few times and saw something happen when I try to connect. I lost my connection to the wifi I normally use and it Will try to connect to "Chromecast5685.v," as wifi.
I dont know if this is normal, do someone have a solution?
David_K
Chromecast5685.v is the device's setup network that it itself broadcasts when it is not connected to your Wifi network. Try these steps:
Need help with setup? Troubleshoot common Chromeca… - Google Nest Community
Kimy
Thanks for your help, @David_K.
@Simen2360, I hope you've found the answer you're looking for. If you're still in need of assistance, please let us know, as we would be happy to answer any questions you may have.
Kimy
Kimy
Kimy
