My chrome cast remote is not pairing after factory reset. Tried pressing both buttons as suggested o
Shubas
My chrome cast remote is not pairing after factory reset. Tried pressing both buttons as suggested on screen but can't pair
Kimy
Hi Shubas,
Thanks for posting and for being a step ahead of us. I’m assuming you’re using a Chromecast with Google TV since that is the only version that came with its own remote. Let’s try this workaround and let me know how it goes:
  • Remove the batteries and give it a 2 to 3 minute rest.
  • While the batteries are out, press and hold down the power button for 15 to 20 seconds to fully drain any static power left on the chipset/motherboard of the Chromecast Voice remote, then release the button.
  • Let the remote rest again for 2 to 3 minutes. Take this time to unplug the Chromecast device from power and give it a 1 minute rest before you plug it back in.
  • Try to pair again.
  • If it persists, you can factory reset the remote one last time and pair it again.
We look forward to your response.
Kimy
