No signal problem
Rahulkonda
I have a good wifi .good tv,brand new google chrome cast but when I connected it .it is showing no signal .any inputs
6 REPLIES 6
Byteguy
That sounds like your Chromecast may not be getting any power (or not starting up).
Do NOT plug your Chromecast device into your TV's USB ports.  They often don't provide enough power.
Look at your Chromecast device?  Is there a light on it?  If so, what color and is is flashing or solid
If there is no light, it is not "on".  Make sure it is plugged into the wall using the power-block and cable that came with it.  Try another block and cable (they are standard) if you have one.
If you still don't have a light, it may be a defective unit.
Let us know.
That was my first thought. However, depending on the default device communication, they might not be cross platform read enabled or some default configuration may have been altered inadvertently.
Kimy
Thanks for helping out, @Byteguy and @87nhustleProd.
@Rahulkonda, have you had the chance to try the suggestion above? If yes, how is it? I look forward to your response.
Kimy
Kimy
I wanted to follow up and see if you still needed help. Please let me know if you still have any concerns or questions.
Kimy
Kimy
Hello Rahulkonda,
Kimy
87nhustleProd
More than likely, your tv has Chromecast built in. Check to see if and make sure you configured your devices correctly and on the same wifi network. Hope that helps. ✌️
