07-28-2025 12:53 AM - edited 07-28-2025 12:58 AM
Alternative title:
Re: Feature Request: make Chromecast power on / off multiple devices
A few years ago, I expressed my frustration about not being able to simultaneously power on a non-CEC TV and a CEC receiver using only a Google Chromecast remote. I had mentioned finding a workaround but never posted it because I accidentally broke it before understanding how it worked. Then, somewhat randomly, it started working again.
That was until recently, when I decided to experiment with the settings on my TV, receiver, and Chromecast, which, of course, broke the setup again! However, I've now rediscovered the solution and want to share it for anyone encountering similar issues in the future. I can't guarantee it will work with your setup, but it may be worth a try.
How it works:
Here's how my current setup operates: when I press the power button on my Google Chromecast remote, both the TV and receiver turn on simultaneously. Pressing the button again immediately turns off the TV, while the receiver powers down automatically after 15 minutes.
My setup:
Google Chromecast Settings
Before adjusting the next few settings, you might need to set up the buttons for your receiver and TV. I've only configured the volume button for my receiver (1) and the power button for my TV (2).
Onkyo HT-R494 Settings
Here are the settings for my Onkyo HT-R494 receiver. I'm not entirely sure if all of these are strictly necessary, but this is my current configuration:
Final remark
It's possible that the receiver needs to enter its automatic sleep mode (after 15 minutes of inactivity) for the simultaneous power-on function to work correctly. Manually switching everything off and then attempting to power it all on at the same time might not achieve the desired outcome.
I understand this setup might seem a bit convoluted, but hey, if it works and keeps your old TV going, that's what matters! I'm glad if it could help you somehow. Cheers!
07-31-2025 02:02 AM
I've noticed, with this setup, when I use the power button of the Chromecast remote, the first thing I can see on the tiny screen of the onkyo receiver is Volume, as if I was changing the volume despite it remaining the same.
