08-07-2022 04:22 AM
Hello. I've been trying to transmit the image from my cell phone to chromecast for a while, but without success. Even if I try through third-party apps, Google Home or system settings, none of the options work.
Also, I use a dualshock 4 controller to play Xbox Game Pass, I also use a bluetooth headset and both work poorly via bluetooth. The control and the headset have several lags and interference, probably caused by the distance. The issue is that the Chromecast is at most 4 meters away.
08-10-2022 07:05 PM
Hello Honorio,
Thanks for reaching out. Please try the steps listed below and let me know how it goes:
Jennifer
08-10-2022 07:05 PM
Hello Honorio,
Jennifer
08-13-2022 07:23 PM
Hello there,
It's me again. How's it going? Did those steps help?
Jennifer
08-14-2022 11:16 AM
Hi Jennifer. Thank's for your time.
These steps didn't help me. It seems that the problem is the distance. When I put the devices close to the Chromecast, bluetooth works fine. The strange thing is that the distance I put them is about 4 meters, if I put them at about 30 centimeters they work fine, if I move away more than 30 centimeters don't work.
08-14-2022 05:54 PM
Hi Honorio,
Thanks for getting back to us. All Bluetooth devices have different Bluetooth distance ranges. Therefore, we recommend you keep your Bluetooth device that's connected to the Chromecast with Google TV via Bluetooth as close as possible–to ensure you get the best performance.
Jennifer
08-14-2022 06:00 PM
Yes, but the same devices tested with the cell phone work with greater distance. The problem is with the Chromecast. Waiting for the next updates for some correction.
08-14-2022 06:11 PM
Hello there,
Understood. I'd suggest you send feedback about this using the Google Home app. Every bit of feedback helps a ton. Here's how. In the meantime, do you still have other questions and concerns?
Jennifer
08-14-2022 06:26 PM
Thanks for your ideas. See you 😉
08-14-2022 07:09 PM
Hey Honorio,
You're welcome! since you don't have any more questions and concerns, I'll go ahead and lock this thread. If you have any new issues, updates or just a discussion topic, feel free to start a new thread in the Community.
Have a good one!
Jennifer
