Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
03-20-2025 10:49 AM
03-10-2025 06:56 PM
I have a Gen1 CC audio and it’s not connecting. Same error “Not a trusted device” I already made the mistake and I did a factory reset.
03-10-2025 07:00 PM
Reposting my experience here:
2nd generation Chromecast model NC2-6A5: I reset the device to factory default, following the series of suggested fixes issued by Google. As others have mentioned, I could no longer connect to the device to set it up. Following the advice noted in this thread, I set the phone's date to March 6. I was able to connect to the Chromecast and get it back on WiFi, so others that mentioned a certificate expiry issue may be right. I still cannot connect to the device to stream anything, but with fingers crossed , Google will be able to push the fix to my device.
03-10-2025 07:06 PM
Change the date on your phone back to March 6th and you will be able to set it up. However until they fix the expired certification, the moment your chromecast connects to the Wi-Fi it will realize the date is the 10th and it's past the certification so you will not be able to stream. Hopefully when they renew this your device will be all ready to go.
03-10-2025 06:59 PM
Restaurar aos padrões de fábrica foi uma das primeiras coisas que todo mundo fez após passar muito tempo tentando conectar sem sucesso. Agora, mais de um dia depois da falha vocês avisam isso.
03-10-2025 07:04 PM
Hi There
My Chromecast stopped working from my phone and iPad yesterday. I reconnected it and it keeps on saying enable local networks. They are enabled. Is this the problem you are currently trying to fix?
03-10-2025 07:05 PM
I have been having issues for 2 days and did a factory reset loke the original Instructions suggested. Now I'm stuck when this matter be rectified
03-10-2025 07:09 PM
will someone sent me email when this is fixed
03-10-2025 07:07 PM
as of 10 pm eastern time on 3/10/25 my Chromecast is not working
03-10-2025 07:10 PM
I just factory reset my device since it showed error showing that my Chromecast is using outdated firmware. How to fix this and get it online. Please help
03-10-2025 07:30 PM
Exactly! did they change FAQ page already to not do that? like a thick red banner on top saying that 2nd gen devices experiencing an issue, and thus owners should not follow FAQ, and NOT reset their devices?
03-10-2025 07:16 PM
Eu restaurei o meu que apresentou problema desde sábado. O que devo fazer? Aparece todas instruções de instalação e não pega.
03-10-2025 07:17 PM
Any updates on the fix? I'm in NZ and it's driving me nuts that I can't cast my streaming services.
03-10-2025 07:20 PM
El problema con mi Chromexaste esta hace más de 24 hrs.... hubiera sido bueno saberlo antes de haberlo reiniciado a valores de fábrica.
03-10-2025 07:20 PM
Maybe the next time, acknowledge the issue and issue the warning a bit earlier than that?
Already reset. BTW, your users are conditioned by now to hit reset. I don't think I need to elaborate why is that.
03-10-2025 07:22 PM
What is the eta on a resolution? This is a major inconvenience with little communication coming out.
03-10-2025 07:26 PM
Not reset the device, eh? When your FAQ are riddled with suggestions to do exactly that! Get real, google. Or did you get rid of any thinking person?
03-10-2025 07:25 PM
What if I've already factory reset my devices? I've been constantly trying to connect both Chromecast 2nd gen that I have and they continue to fail.
03-10-2025 07:27 PM
Please email me when fixed #
03-10-2025 07:31 PM - edited 03-10-2025 07:32 PM
Where is communication on how you are going to reach out to those who already did do factory reset as per your FAQ instructions?
03-10-2025 07:32 PM
Well???
03-10-2025 07:33 PM
Well it's weird, you knew it was going to happen.. right? If you didn't, it's even worse...! Big Google for a long time, but not so much right now
I have 2 unusable devices.. and I would have appreciate to know before it happens, bad customer experience.
03-10-2025 07:35 PM
I did factory reset my device. Pls, provide instructions to set my device back up.
03-10-2025 07:35 PM
Keep me updated when this is fixed. I already factory restarted my device
03-10-2025 07:42 PM
Wow glad I find this post after I factory reset my device. Working in t3ch that's always one of the first few things to try. Power cycle it, if that doesn't work try factory reset....
03-10-2025 07:41 PM
How much longer until it’s fixed? Are we talking hours, days or weeks?
03-10-2025 07:59 PM - edited 03-10-2025 08:05 PM
REF: Chromecast 3rd gen; unable to authenticate re-setup of device. Authentication of the 4-5 alphanumeric characters (input/ popup) does not come up in the setup process. Authentication error is then displayed on Android (Pixel mobile phone) screen.
How will we be notified of the instructions to reconnect our devices if we have already reset them multiple times?
Will this be distributed as an update with those necessary instructions?
03-10-2025 08:06 PM
Chromecast was acting up, ended up removing the device from my Google Home favorites.
Tried to reinstall it, but having issues. After looking to see if others had something similar, it looks like I wasn't alone with this recent technical issue.
Is there a contact / email list I can add myself on to be notified when the issue has been fixed so I can reinstall my chromecast?
03-10-2025 08:11 PM
Any update on this, I factory reset mine and now I can not get it back .
03-10-2025 08:12 PM
Y ahora cuando darán la respuesta de que se debe hacer para los que reiniciamos los dispositivos?
03-10-2025 08:15 PM
Already done the reset and stuck like anything, I mean this is really unethical, There should be heavy tariff from every country on every product by google
03-10-2025 08:15 PM
Thanks for working on this. Would appreciate to know when solution is in place
03-09-2025 05:53 PM
No se pudo verificar Chromecast. Esto podría deberse a que el firmware del dispositivo no está actualizado.No se puede reiniciar porque sinlo haces te dice que hay que autenticar es como si al dispositivo lo hubieran dado de baja. NO HAY MANERA DE SOLUCIONAR ESTO por mas intentos que uno haga. Quiero soluciones de parte de google ya sea que lo arreglen o de lo contrario informen que no va más estos dispositivos. PD. soy de argentina
03-09-2025 05:59 PM
Tengo el mismo problema desde hoy. Espero lo solucionen para mañana. Domingo de bajón sin tele
03-09-2025 06:07 PM
Estoy igual desde hoy
03-10-2025 01:05 AM
Mismo problema desde España , en Extremadura
03-09-2025 05:59 PM
Me pasa lo mismo desde hoy. En mí compañía de internet me dicen que es un problema de Google. Venía funcionando bien y de repente cayeron todos los Chromecast de la casa. Habrá solución?
03-09-2025 06:04 PM
Desde hoy 09 de marzo del 2025, el mismo problema, mis 2 chromecast quedaron sin uso... alguien ya tiene la respuesta??
03-09-2025 06:09 PM
No. La verdad que vi post desde hace 7 hs en algunos lugares del mundo que esta este problema. Un bajon..
03-09-2025 06:16 PM
Yo estoy exactamente igual...no entiendo nada, he probado de todo... alguien sabe solucionarlo?
03-09-2025 06:17 PM
Hay que esperar a ver que dice Don Google.
