GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,144 REPLIES 16,144
When will this be update??
Anonymous
Not applicable
Cuanto tardarían en dar solución...he hexo restaurar de la fabrica a mi dispositivo ya q tardaron mucho en avisar
Gracias
Still facing connecting problem
To offset the many inconveniences caused by the failure, it would not be a bad idea to offer users 4th generation equipment at no cost.
Think about it!
Juanjo.
Vi prego potete risolverlo e da giorni che non funziona ne ho bisogno stasera.
come mi avviserete quando posso ripristinarlo
I chose Google Chrome audio to play music in all the rooms of my house. I have seven of them. It's scandalous that everything is stopped and that a solution hasn't been found yet! If it takes any more time I'll replace them all with other devices. Goodbye Google.
I have already done a factory reset before, please give me some instructions to solve this problem.
I have factory reset my device, and now it cannot receive updates. Please find a solution quickly. You should check the updates before releasing them.
Deberían poner un mensaje en la app Google home, por qué yo si restablecí a fábrica uno de mis dispositivos hace dos dias, por qué así lo sugiere el solucionador de problemas es la app y apenas hoy veo un correo que le mandaron a mi hermana y no a mi donde explican qué hay un problema, así que la difusión no está llegando a todos los usuarios de forma oportuna, pero todos si entramos a la app para ver qué sucede, entonces ahí deberían de informarnos, qué do al pendiente de cuando lo solucionen por que realmente si ha sido muy frustrante
If you already resetted the device and you cant get it setup again to your wifi, Just set your phone or tablets clock manual and to March the 7th. Reset the CC and set it up with Google home. That way Google can roll out the fix for your device
Is there any way to manually force the update?  Or is it a waiting game?
Agilizar esse procedimento está afetando o funcionamento
Fiz o reset .
Preciso de orientação de como configurar.
Hello, I performed the factory reset but it let me finished the setup. My Chromecast is now connected and added to my home devices y Google Home app. However I still cannot stream any videos on it even when it appear in the list of screens. Also I can't change the name of the Chromecast
Hola! Gracias!
Pero cuantos dias mas creen que necesitan para resolverlo, siendo una de las empresas mas importantes del mundo. Ya paso a ser vergonzoso!
How will I know the update has happened?
If you did a factory reset, set back the date on your Phone before 9 of march and reinstall your Chromecast.
If I  do that will I lose the 2 new cameras I bought and connected?
I use 4 units for classes. I havent been able to teach for a whole week. Already lost 1 student. What are my options to fix it ? Buy a Roku, or MI Stick ??
Aunque leo por internet que ya se está implementando una actualización de firmware para Chromecast 2, con una nueva Versión del firmware del sistema: 467165 Firmware del Cast: 1.56.467165 yo sigo teniendo la Versión antigua del firmware: 275994 Firmware del Cast: 1.56.275994
Dicen que está implementación se está haciendo por fases y que no todos recibiremos la actualización inmediatamente. El porcentaje de implementación es de aproximadamente un 5% y los dispositivos que no estén configurados y conectados a Wi-Fi no podrán obtener la actualización.
Pero ¿qué es eso de la configuración? Los usuarios reportan que para obtener la actualización el dispositivo debe estar conectado y uno informa que tuvo que cambiar manualmente la fecha de su móvil a una anterior al 9 de marzo.
He probado eso pero a mí la actualización no me ha llegado. Al He cambiar la fecha y probar a actualizar el Chromecast por el Google Home me salen mensajes de autenticación inválida y que tengo un certificado de Google no fiable
How much time plzz revert update and sove my problems
O meu Chromecast não está querendo se conectar no wi-fi. Resetei ele, mas o problema ainda continua
How is the Chrome cast gen 2 updated? Can i force a update and how?
No the device updates automatically after reboot. In my case the fix has not been updated yet (the Netherlands)
Ok, and if there is no solution, will you send me two new devices? Since that is the amount I have at home... or will we just have to suffer the loss?
Estou com problemas em3 chromecast
Bom dia meu Chromecast está sem a configuração estou tendo problemas o meu Google home tenta conectar meu Chromecast e não dá certo
I have 2 identical 2nd gen chromecast devices.
1. connects to the wifi network and I expect will get the fix,
2. the other one Does Not connect to the wifi network. How do I / we fix that one?
Estamos aguardando porque e útil pra min
obrigado
deusvaldo oliveira
I have also factory reset my Chromecast, pl help to resolve the problem
Anonymous
Not applicable
It just dawned on me, not only did I have six Chromecast audio devices active, now not working,  I still have three sealed in the box that were my spare back ups. Those three have never been activated.
One of my current used devices I did reset and to get it back online to actually just see Internet I use the set the date back hack during google home resetting it up.
Not sure if it will receive the pushed fix or not,  what is your plan is for those that are no longer activated including my spare three brand new? how about come out with a fix within Google home as well that will be able to handle this problem going forward in the future, or will I now have a limited time to activate the sealed Chromecast audio units once the fix is available?
Still no solution after factory reset. We are waiting for instructions from Google.
I have a Chromecast gen 2 and Chromecast Audio. Both still not working even after several reboots of Chromecast, phone and router. Update seems not have reached the Netherlands yet.
DICA VALIOSA:
Dia 09/03 o meu parou de funcionar, o modelo 2.
Hoje dia 14 eu vi uma notícia que o Google estava corrigindo o problema, mas eu havia resetado o meu para configuração de fábrica, descobri que posso reverter isso,
Faça o seguinte, entre nas configurações do seu celular, procure por data e horário, tire da configuração automática e mude a data manualmente para o dia 08/03. Após isso reinicie o celular, abre o app home e inicie a configuração.
Você vai conseguir fazer mas vai continuar sem conexão, após isso só esperar o Google resolver o problema e atualizar o app sozinho.
Please provide the fix as soon as possible. It's already been a week and we have factory reset the chromecast. Provide the solution ASAP
Necesitamos por favor nos ayuden a arreglar el problema
If the device is connected to Wifi, how will I know when the fix has been installed?
