GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,144 REPLIES 16,144
"Your device must be connected to receive the update "!!  Isn't that the problem, our devices won't connect and are not connected???
Look in the router settings to see if your Chromecast appears connected. Only then will you know if it is connected or not.
I have reset it to factory settings, but I could not reconfigure it. To reconfigure a new device you have to change the date and the mobile date to 8/3/2025, and this way it lets you add the device but the sending still does not work. Just wait for the new update, at least this way you can leave it added until it arrives.
Cnr1
Change your device to the 07/03/2025 not the 08/03/25, it will then work
The connection was bad, and when I reset it, it couldn't be connected. Please let me know when you know how to improve.
I had the device unplugged yesterday it is plugged back in now I just want to make sure this gets fixed and I didn’t miss it. This is for chromecast and we have literally had no TV for days.
Anonymous
Not applicable
My chromecast is now working. Thanks
F1drop
Which country?
Anonymous
Not applicable
Sorry, UK. I didn't ever get an email but the firmware update happened about 10pm yesterday (GMT)
Nos help aí Google, senão the Jiripoca Will Pew Pew
放置してても数日でまた、観れるようになるんですか?
i managed to connect my google chromecast on the home application but i can't chromecast from my applications like deezer, youtube, netflix... i get an error message saying: micro software obselete. Do you know why ?
Anonymous
Not applicable
He conseguido reconectar al wifi el Chromecast. Espero recibiré la actualización. Para lograrlo he configurado la fecha del smartphone a fecha anterior a 09/03, en mi caso lo he probado con 07/03 y ha funcionado. Solo queda esperar si se actualiza y así funciona de nuevo.
Demasiado tarde. En la ayuda de Home decía que lo restaurante a valores de fábrica...¿ahora qué?...
My chromecast still says offline in the home app and nothing can cast to it. When does the fix roll out in Denmark??
You guys are so lame
¿Cuánto más falta?
What means of the devise is connected is just plugging into HDMI of my TV like I usually watch the on-demand programs? or anything specific I need to do?
Anonymous
Not applicable
come distribuirete la correzione?
Qué hacemos los que reseteamos el dispositivo???
I did a factory reset and it's not connecting now. Please provide the solution at the earliest
Wat baken, ik had de fabrieksinstellingen wel terug gezet, hoelang gaat het duren ongeveer? Geven jullie hier een update en manier van werken hoe dit op te lossen?
Es ist echt ein Witz mit euch, heute Nacht funktionierte er tadellos und jetzt geht wieder nichts, was macht ihr da, bin maßlos enttäuscht
Anonymous
Not applicable
Me and my children cannot watch The Chosen! 😭😭😭
Please, tell us how to fix the problem for those of us who did know enough about our Chromecast to try to "fix" the problem by ourselves performing a Default Factory Reset and are now stuck in trouble with your product! Thanks in advance
Hi! I have the same problem.
Where should I file a claim? My device is not working. Since no notifications were sent, I believe I reset it to factory settings. What would be the solution? Thank you.
I am preocupied because its seems like programated obsolescense.
Absolutely ridiculous. ABSOLUTELY.👎
Eu restarei as configurações de fábrica do meu😅😅😅
Please help I factory reset, as didn't realise the problem was your end, please let me know what to do and when I can. Thanks
Hai, ps op je telefoon de datum aan naar 3-maart ofzo.. dan kan je weer connecten, alleen dan wachten op de update
Must my Chromecast be connected to my TV to recieve the fix?
Must the TV be turned on?
None of my devices are showing up as connected in Google Home and seemed disconnected from Wifi.
how am I supposed to receive this fix if I can’t connect them to my Wifi because they are bricked by your certificate???
Pbel
3 out of 5 are now working again.
- 2 Nest mini: a simple reboot worked for those
- Google TV Streamer: disconnected from wifi for no reason, worked once reconnected
- One Chromecast 2nd gen was factory reset: I was able to set it up by changing the date on my Android tablet back to March 7th (before the certificate became invalid).  So it is connected to Wifi and still shows up in Google Home but I still can't stream from mobile devices.  So changing the date back before the certificate expired seems to help, but will it get the fix anyway?
- The other Chromecast 2nd Gen was not powered at the moment the certificate expired, I just powered it and it is not able to connect to wifi and show a code like R5Y6... I can't see it on my router's device list, and I have no idea when was the last time it was powered on.
So, what should I do with the 2 chromecast 2nd gen that don't seem to update themselves??
Fiz a restauração de fábrica. E gostaria de ser avisado quando for sanado o defeito
I try to submit the form and it is not sent and generates the following log: Refresh the page and try again There was a problem with the form.
Yo lo reestableci pensando que era problema de mi wifi pero resulta que no. Espero que se solucione pronto
Anonymous
Not applicable
All my crome audio devices are working again 🙂 I had to take the power on some for a second and when it reconnected to my network it updater and work perfectly 😃
Qual seu país?
Do you from?
How many days ?
Ik heb gereset en nu pakt die hem niet meer krijg geen verbinding
In case of factory reset: set your phone's date to March 8 and you can connect to it again. Not use it, mind you, but it won't throw an error setting up and it should be connected from that point onward. Hopefully this allows it to receive the update.
