Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
03-20-2025 10:49 AM
03-12-2025 05:05 PM
Pour moi j'ai réussi à le reconnecter en changeant la date de mon cellulaire soit le 8 mars avant le bug et j'ai pu le paramétrer mais la diffusion de contenu ne fonctionne pas encore
03-12-2025 05:01 PM
Le souci c'est que le bug a été connu bien des heures plus tard avant qu'on sache qu'il ne fallait pas réinitialiser ce qui fait que beaucoup d'entre nous avons suivi l'aide sur le site qui conseillait en dernier recours de réinitialiser.
03-12-2025 05:40 PM
Exatamente . Eu redefinir o meu ontem, desde de domingo tentando conectar e sem conseguir .
Até achei que fosse a internet .
03-12-2025 05:01 PM
Would this be relevant to this issue please?
new TCL tv. When setting up google tv it says my correct password is incorrect. When I choose alternate login for Google it brings up 2 previously removed pH numbers and won't let me use the current verified pH number. Ii have changed google password, checked firmware (auto update) and turned tv off and on again. Logged onto goggle account with old ipad no problem. Going GG insane
03-12-2025 05:01 PM
Que atualização pra ontem , ou certificação ... Pois ultilizo o dispositivo sempre , minha Tv só funciona com ele , não assisto tv , quero reparação o quanto antes ...
03-12-2025 04:52 PM
Ok quando vai ser restaurada ?
03-12-2025 05:06 PM
Quando vai ser restaurada?
03-12-2025 05:05 PM
Buy a firestick
03-12-2025 05:04 PM
"I've already reset my device. I'm looking forward to your instructions. Thanks!
03-12-2025 05:05 PM
i can't believe google still hasn't fixed the chromecast problem. it's been 4 days and thousands of people have been out of service. we should sue google
03-12-2025 05:06 PM
03-12-2025 05:07 PM
Why don't you find your own problem when Chromecast doesn't work?
Google won the MVP!
03-12-2025 05:08 PM
If you've already reset your Chromecast, just set your phone's date back in time to March 8th, then try setting it up. It should at least get it back online so you'll get the fix when it comes out.
03-12-2025 05:07 PM
Quedo atento a la solución
03-12-2025 05:09 PM
So?
03-12-2025 05:10 PM
In that momento, i reset to factor y my Chrome cast 2nd generetion, please give me a solution. Thank you
03-12-2025 05:34 PM
Confirmed fix if you factory reset your device. Manually set the date on your mobile device to any date before march 8. Once set you should be able to pair your Chromecast.
03-12-2025 05:44 PM
How do you do that, I can connect if connect my smartphone as it Chromecast is a network. Then it goes off and I cannot get access to the device, is there another utility I can use rather than google home?
03-12-2025 05:15 PM
I did a factory reset, and now I don't know how to fix it. Is there a way to get on a waiting list or find out how to resolve this?"
03-12-2025 05:20 PM
Cadê a segurança e deveria dar outro diapositivo para aqueles que sofre este problema aqui em sp
Espero que resolva isso gastei dinheiro e meu reembolso como fiico
03-12-2025 05:25 PM
So I should just leave it on? I rested before coming here.
03-12-2025 05:27 PM
Thank you for letting us know, this is great customer service
03-12-2025 05:28 PM
Debería haber demanda contra Google,por su negligencia nunca informó al usuario sobre la caducidad de los certificados y los daños que han ocasionado al ni siquiera dar respuesta oportuna a la problematica
03-12-2025 05:28 PM
Cuanto tiempo más hay que esperar
03-12-2025 05:30 PM
Comparte
03-12-2025 05:32 PM
According to several blogs, they say they have already started rolling out the update, but they haven't said anything about how long it will take to arrive. The problem is that the 9th is the case.
03-12-2025 05:32 PM
This is it I’m done with Google products the Chromcast was my last Google product I will go with Roku or Apple TV. They probably are push some kind of update. I would not be surprised if they are trying to push Google TV’s.
03-12-2025 05:36 PM
Great so after nothing else worked, I try the reset last night, then I get a email today with a link to this page that warms don't do factory reset🤦
03-12-2025 05:38 PM
I found this URL performing a search on the internet:
The news post URL below is reporting that a 10 year certificate is causing device authentication issues. Google is not reporting what the issue is exactly, but the article says a post to reddit a person was able to chase down the "certificate" chain record (Apparently the reddit poster had access to software tools to access the devices OS memory, be it some EEPROM or other kind of non-volatile memory) The most curious thing is the date 3/9/2025, that is when my gen 2 device stopped working.
Google’s 10-year-old Chromecast is busted, but a fix is coming - Ars Technica
03-12-2025 05:38 PM
Se você fez o factory reset, desligue sua internet, volte a data do celular e configure novamente seu Chromecast que funciona.
03-12-2025 05:37 PM
Google falhou grandão sobre essa instabilidade .
Tenho tv das antigas , que nao é Smartv e hoje perdemos a funcionalidade de um item que me faz falta no dia a dia .
Espero que façam funcionar novamente . Pois um erro do Google , vai me custar caro , tanto pra uma tv ou um novo aparelho , que certamente será lançado recentemente ou já deve ter algo novo . E pra forçar a compra fazem o outro parar de funcionar .
03-12-2025 05:39 PM
It appears in the journal thay you have updated the firmware but it doesn't happen. The Chromecast is connected to the internet and has not been reset. It's from the second generation. but it doesn't work. you can clarify?
03-12-2025 05:39 PM
Aguardamos una resolucion... efectivamente antes de que admitieran este problema, como sucede mucho que deje de funcionar, ya factory reset 😭
Aguardo notificacion de como resolver el problema.
Gracias!
03-12-2025 05:40 PM
Qual prazo?? Vou acionar odcs.
03-12-2025 05:43 PM
Just fix the issue already. I need to watch my series.
03-12-2025 05:43 PM
I factory reset it during troubleshooting but was able to reset the device by changing my phone day and time back before march 9th.
03-12-2025 05:42 PM
Hay q dejar de comprar productos de Google
03-12-2025 05:46 PM
Bitte und hilf mir, das Problem zu lösen
03-12-2025 05:46 PM
Já estou a dois dias tentando conectar na TV e não consigo, resolvam o mais rápido possível. Acabe reiniciando pois não tive informação antes, fui obter a informação após tentar configurar do início novamente. Preciso de ajuda pra configurar, não estou conseguindo mais, está dando erro.
03-12-2025 05:51 PM
Vc conseguiu?
