Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
03-20-2025 10:49 AM
03-09-2025 05:45 PM
#GlobalOutage 🛜👇
03-09-2025 05:36 PM
In Argentina Chromecast 2nd Gen same problem . no autentification . Yesterday works fine. factory reset doesnt work. authenitficacion Trouble!! Please Google Help for fix. (sp : Tuve el mismo problema ...no se conectaba e hice reinicio de fabrica ...hice todos los pasos con Home App y no autentifica. Por favor Google corrija el problema!!! se ve que es masivo el problema en general. Gracias ! I
03-09-2025 05:55 PM
Hi, same problem here in Argentina. I think they did it intentionally. Me parece q lo hicieron a proposito estos HDP
03-09-2025 05:36 PM
Chromecast worked fine for years, but today it stopped working. Tried a reset to factory settings but I just can't complete the setup. The Home app can find the device but, while trying to establish a connection, it indicates that it can't authenticate.
I tried everything. Unplugging and plugging again, switching WiFi from 2.4 to 5.8, restarting modem, updating Home app... nothing worked.
03-09-2025 05:40 PM
same issue here
03-09-2025 05:47 PM
I reset my phone, device chromecast and wifi router, its 9/03/2025 is a global error problem?
03-09-2025 06:12 PM
03-09-2025 07:03 PM
Mismo problema acá. Después del reset aparece el mensaje "No se pudo autenticar" y ya no puedo transmitir contenido desde mí celular, por ejemplo Netflix.
Same problem here: After the reset I get the message "Failed to authenticate" and I can no longer stream content from my phone, for example Netflix.
03-09-2025 07:06 PM
Lo mismo aca, desde la tarde que estoy tratando de arreglarlo y nada, tengo dos televisores con chromecast y ninguno anda. Hice todo lo que sugiere el troubleshooting pero no funcionan. No pienso comprar un google TV porque a un CEO se le ocurrio dejar de dar soporte a dispositivos que se usan en miles de hogares, que la chupen y la sigan chupando.
03-09-2025 07:05 PM
Got the exact same message, tried restarting the device twice- did nothing, saw a reddit post suggesting that if I clear my phone's Google Play store data and cache that would solve it: it did not, a YouTube tech support video suggested an auto-update may have caused the issue and that going into the device settings and removing that update might solve the issue: plan to try that when my roommate gets home and seeing if that does anything.
03-09-2025 08:30 PM
Hubo una actualización hace unos días y desde ahí dejó de autenticar
03-09-2025 07:17 PM
Same issue still not resolved?
03-09-2025 07:20 PM
Not yet
03-09-2025 08:11 PM
Same issue here... Nothing is working
03-09-2025 08:12 PM
Wonder if this is their way to get us to buy new ones... If that's the case I will go a different route.
03-09-2025 08:14 PM
Un usuario de Reddit encontró el problema. EL CERTIFICADO DE LOS DISPOSITIVOS CHROMECAST CADUCÓ el
9 de marzo de 2025 a las 16:44 GMT
Ver hilo: goo.su/GupfEAg
03-09-2025 08:36 PM
en base a lo que leí, pude lograr lo siguiente.
en un principio como no me funcionaba lo resetee de fabrica, entonces una vez reseteado ni siquiera me dejaba volverlo a configurar. como el problema se basa en la fecha del certificado intermedio lo que hice fue cambiar la fecha de mi celular y ponerlo en 8 de marzo.
una vez logrado pude configurar el chromecast, y me da señales de vida como si estuviera listo para castear con sus fondos de pantallas.
lamentablemente hasta eso llegue. ojala alguien pueda hacer q funcione!
03-09-2025 08:36 PM
I have the same issue. It says:
We couldn't authenticate your Chromecast.
03-09-2025 09:28 PM
Same here. Not sure how to fix it.
03-09-2025 09:48 PM
Same in Thailand. Factory reset device, redownload home app, even got authentication codes from Google thinking maybe it was problem with my Google account. Updated the address for the device. All to no avail. It's an old device first set up in 2010. Want me to buy a new device? Okay, but how do I know it will work?
03-09-2025 10:51 PM
Don't worry, my friend, my device is from 2018 and the same thing happens to me.
03-09-2025 10:35 PM
Same here. Finds it but won't authenticate.
03-09-2025 11:34 PM
2 of mine are not even in de home app anymore, cant find it either
03-09-2025 11:21 PM
Same.
Mine stopped working while I was using ten chromecast. It was in the Netherlands at approximately 20:45 (Timezone UTC +1)
03-09-2025 11:25 PM
Hier ook, ik word er gek van
03-09-2025 11:25 PM
I got yesterday the same issue with e gen 2 Chromecast. It couldn't be added any more to my home using Google home.
03-09-2025 11:30 PM
Same here, I am in the Netherlands
03-09-2025 11:45 PM
I have this problem too. Is there any solution?
03-10-2025 03:45 AM
NO
03-10-2025 02:01 AM
same today in New Zealand
worked fine this morning 12 hours later not
03-10-2025 02:27 AM
Still nothing from google on resolution or at least acceptance that they are working on it
03-10-2025 02:29 AM
03-10-2025 02:48 AM
Bonjour,
Merci pour cet article 🙂
Malheureusement il y est précisé " Google déconseille de réinitialiser le Chromecast concerné aux paramètres d'usine", ce que tout le monde a fait et sans communication de la part de Google c'était évident que l'on tenterait cette manoeuvre...
Donc que va-t-il se passer maintenant que tout le monde à réinitialiser son Chromecast?
Ce que je reproche à Google c'est son manque de communication 😤, c'est lamentable!
Bon je vais aller acheter un fire stick mais pas un Chromecast c'est sûr...
03-10-2025 02:32 AM
People, looks like Google has 'bricked' the second gen Chromecast. It's little more than hockey puck shaped e-waste now. RIP. 😡
03-10-2025 02:39 AM
bonjour
est-ce que cela veut dire qu'il n'y a aucune solution pour ce problème?
03-10-2025 03:28 AM
Exactly same here ,have done factory reset and now just stuck trying to set up ,but keeps saying it can't communicate with the device ......help!
03-10-2025 04:16 AM
search google "google chromecast outage"
seems its global outage for Google to resolve
03-10-2025 03:36 AM
I have reset my device twice, as it stopped working yesterday, and it keeps telling me it can't authenticate my device.... @Google@Google......please help resolve
03-10-2025 03:38 AM
I am from South Africa....
03-10-2025 03:41 AM
Same Here, been follow all instructions but the result still same..
With notif:
• Could not communicate
• Could not authenticate
What happened really?
Is it out of date and can not use anymore?
