GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,137 REPLIES 16,137
Kevindavis33
Absolute joke. 23 hours and counting. Make us pay for the devices to watch the subscriptions we have to pay for. The consumer is the one losing money here through no fault of our own. This should be fixed by now. I hope every chromecast user gets some compensation for this complete mess. I understand it's technology and these things occure, that's the modern age, but this is ridiculous now.
Mibop
Ayer me pasó lo mismo.
Sabemos cuanto tiempo puede pasar?
Como sabremos que ya se ha solucionado o lo que tenemos que hacer para que podamos seguir utilizando el chromecast?
matthieubrucher
A bit too late as THIS IS THE ADVICE YOU TOLD PEOPLE!!!! I already did factory reset.
FAOD
How do you plan to notify us when an expected fix is coming? And for us that have factory reseted, how will you provide us the instructions you mentioned?
Kirtipur2
Please be quick! It's been a day already!
Mude a data parando dia 08 e refaça a configuração
Sirenanegra
Estoy casi al borde del colapso, tengo tres Chromecast y nada funciona
Mude a data para o dia 08 e refaça a configuração
Perspectalog
Ah just factory reset it obviously 😅 like two times...
Vishnu1981
Same problem for me aswell. I did factory reset.please send instructions.
imposta una data antecedente al 8 marzo sul cellulare dove hai installato google home e riassocia la chromecast. vedrai che funziona l'associazione. per il ripristino dello streaming dobbiamo antedere google.
Pierre38320
Comme beaucoup j’ai suivi la procédure et j’ai réinitialisé mes 2 chromecast. J’espère vous allez apporter une réponse à tous les utilisateurs de cet appareil. Merci
Jindabyne
How will Google send the instructions if we all did a Factory Reset?  Is it sent by email to all Google subscribers?
colo5k
It's great to read "don't factory reset" after doing the factory reset...
Hallando
Change date on your phone to 7 of March, then you can set up you chromecast and wait for an update, worked for me🙂
Seriouslytho
Well that's brilliant. Troubleshooting 101: factory reset. Did that before searching the authentication error...
Hiddledip
Any update on this? @GoogleNestTeam
Even a simple "still working on it, no further updates" would be highly appreciated.
I'd like to be kept in the loop with a regular update, even if nothing has happened yet - feels like you care
Caduser
I have said this before, but despite your decision to fix this issue, it's really important for Google to understand the scope of influence the group of people have who use devices like CCA. This group, most of whom are active Redditors, are the people helping people with technology and their decisions to invest in it. Don't underestimate us. CCA is one of my personal favorite devices ever made, and has been a major reason to further invest into Google's ecosystem. I will not stay without it.
LexiC
Ya to late .. already factory reset mine... I mean that's how most of us fix connection issues with the Chromecast so that was our first thought was to factory reset... so many people have done this. Hopefully we can fix this.
IRONcladUK
Same... First thing I did then after a day of no success saw the first post re the issues...
Quite disappointed with this whole situation...
gerent
I hope this is not planned obsolescence, because I happen to like my casting device.
Daniellexx
Hopefully a reply here as soon as its fixed so people know when it's able to be used again. Most of us paying for subscriptions on apps we cannot use. So frustrating.
Mercedes13
WHOEVER FIRST MENTIONED SETTING YOUR DATE BACK BEFORE THE 8TH IS A GENIUS!!!
sshriwas
Is there a expected time to get a fix?
moisie
Normally when something doesn't work, you have to try several things and eventually you can try a factory reset. And then this time, the advice is to NOT do the factory reset... POOF too late... Hope the solution to that one will be easy and sufficient.
Whiteorourke
Same issue here in Ireland, hopefully this will be fixed very soon
Ali1138
Hi, I have thus chrome home for 5 years but yesterday suddenly found the chromecasting not working I tried to switch off and on that it's says we couldn't authenticates your chromecasting, but I don't know really what to do?
themury
Muchas gracias aguardo respuesta como seguir cuando lo reiniciamos de fabrica...
aazz2100
I have already factory reset my device 😞
LOL  ME TOO
I also factory reset but you can get the device back on your WiFi (at which point it will eventually receive the update) by changing the date of the phone or device your using to connect to the Chromecast to the 8th March or earlier. Then go through the set up as directed on the screen
Try to update your device date to 1st March 2025 and then connect chromecast to get updated.it will be working after taking time to update.
Fahadii024
XZHENG85
I JUST FACTORY RESET IT. HOW I SET DEVICE BACK? WHERE IS THE INSTRUCIONS?
Per rpima cosa devi riassociare il dispositivo all'app google home: per farlo devi impostare una data antecedente all'8 marzo sul dispositivo e poi puoi associare nuovamente la chromecast all'app google home.
Fatto questo dobbiamo aspettare tutti l'aggiornamento da parte di google per ripristinare lo streaming verso il dispositivo.
Lulu15
Então nada mais justo q vcs arrumarem o q causou o problema pq eu uso o chromecast como ferramenta de trabalho, estou 2 dias sem conseguir apresentar trabalhos devido este problema e já reinicie mais de 50 vezes , espero q vcs se organizem e tragam a solução o mais rápido possível
Furio1
Da ieri sera Chromecast non si collega più e non di riesce più a configurare,home trova il dispositivo ma non riesce ad autenticarlo.
Palmi
Seguo
Anto18
Anch'io ho il solito problema. Da ieri sera ha smesso di funzionare.  Ho provato più volte a riconfigurarlo, lo riconosce ma poi esce"impossibile autenticare il dispositivo"
Ho lo stesso problema. Si verifica solo sulla seconda generazione di Chromecast. Sulla prima versione tutto ok.
O meu tmb está do mesmo jeito des de ontem a noite n está conectando
