GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,145 REPLIES 16,145
Jayvas2
When will I have my device fixed because I need it to work I have great connection
Diego26
Nice to know that is and already known issue, but reading not to restart the system here is too late as Google recommends to do it as first thing in its troubleshooting guidelines.
KCV
Præcis
letmeknowanand
When will the update come what is the ETA - I already made a factory reset
mikekaast
To all of you, who have already reset the device to factory default. do this to get back to start: your device will be ok. Just find an old ipad, or an old android phone, set the date on your device to Mar 8, and setup your chromecast as normal from the google home app, and your all set. BUT you still cant cast anything, you will get the message:  Unauthorized device : until google fix this problem.
Oscar8
I've found a workaround for this issue, check it out
https://vt.tiktok.com/ZSMGy5A3K/
Nahee0323
I have already reset my device…
D004ofi
Au bout de 5 jours toujours rien !!!!!!! Vous vous foutez de la gueule du monde ??????
jsanchez423
¿Cuando esperan que quede resuelto el problema?
Noops
When we will expect the fix
TildeTilde
It's been several days. When can we expect a fix? It's not giving me any confidence in Google products that it takes this long to fix it.
Radean84
Thanks for working on this issue.  I use over a dozen minis as whole house audio and subwoofers connected via chrome cast audio.  Without the subs there is no bass so I’ll be glad to have them working again.  Also heads up that a long time ago the ability to control a speaker groups global volume via voice command stopped working.  I used to be able to easily adjust the volume for all speakers in the group at once but now it only does the one speaker.  I miss that functionality.  Please bring it back if you can.
Bruno1976
Io ho reimpostato le impostazioni di fabbrica, cosa devo fare?
Motta
I have reset my device before seeing this message. When we can expect to return back please?
KCV
Nulstlllet flere gange, senest i 1 time siden. Jeg  har kæmpet med min cromecast fejl siden fredag aften. Først nu ser jeg at der er fejl for alle C. Cast 2. Gen. 😬
Ser frem til en løsning.
anurodh6
Pls keep me informed.
Westislandnz
When will this be sorted?
Please hurry up!
I have used chromecast for years and years,  I love this product and I don't want to have to change brands but if I'm forced into buying the latest chromecast model I will be abandoning google for Amazon.
GreatSUPAcrew45
Un update  journalier de l'avancement du rétablissement serait le bienvenue ..le temps commence à etre long . c'est de la communication élémentaire .
SickadishSchit
You should be providing DAILY updates! It should not take this long for a global company to fix these issues. People rely on these devices
Kain1
I have factory reset it, how long it will take to get the issue resolved.
Lukiss
Has there been a fix yet?  It’s been down since Sunday and the last response I can see from google is Tuesday. It’s Thursday now and I’m paying for streaming services I can’t use.
Douglas_Ng
Thank you.
Glam_Soul
https://youtu.be/2EfKL8Qc8Sk?si=FLbbrvqtb5ViFjtK
Spanish solution.
Solución de un youtuber argentino.
Lo probé y funciona.
Natsb
Can you do one in English 🙏
LaG62
Might be time for a new TV and throw the chromecast in the bin.
Anonymous
Not applicable
Poor communication from Google on this issue. Its been 5 days. Unacceptable!
WonderWorld
This is an embarassing stuff up from a company who should know better. The response time is terrible. This issue affects real people in homes and businesses. Do better.
jarencibia
It's Thursday. Why hasn't it be been fixed yet!?
Travelmonkey68
I just attempted a factory reset before I saw the advice not to!! This issue is costing me money! I have streaming services I am paying for and can’t use because of this issue! It has been going for almost a week!! What are you doing about this and reimbursing users for their costs of missing services? Can you just send me a new one for example so the fix is irrelevant? I’m not happy and not paying for another device!! This one drops out and freezes constantly! When will I be able to stream again?
PeterLo
Shouldn’t there be labels iPhone and iPad? Both mine cannot communicate with my Chromecast (2:nd generation).
Gerry71
Anche io ho questo problema ed ho fatto il ripristino di fabbrica... cosa devo fare?
Gkalikar
Whenever I try it says " Available for specific video sites. After the factory reset it says " Could not communicate with your Chromecast".  Please roll out the solution asap.
Susy1
Hurry up please
Aledal58
How will we be notified that the problem is solved? And how many more days will we have to wait?
Noname666
It takes a lot of time to create a fix.
Google has all email addresses and could notify the CC users.
Susy1
Very disappointing to spend ages trying to reset as it said initially to do at help desk. Only to find out I should not have done that. Frustrating !!!
Bastian25
When is an instruction, for factory reseted Devices ready?
O0timbo0o
Let's be honest, 5 days to fix a certificate issue is BS, they stopped developing this product 5 years ago. The team that did develop it have probably long gone.  What Google have underestimated is the number of people who still use this system but expiring the certificate is a perfect opportunity to pull the plug. People get angry (current situation) then over time start to fade away, won't cost Google a penny. Real shame, such a great little product.  Google should open source it, I'm sure there'd be people able to foster it
Serenaike
At least admit you trolled us all
mgcaravaglio
me too
