GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,160 REPLIES 16,160
I performed rhe reset before I saw this. What do I do?
Checking in to see if there has been any update for those that did factor reset their devices yet.
Hi There,
I hope a solution is coming soon. My husband reset our while he was troubleshooting the issue and now we cannot get it to connect to our devices. Please provide a solution as it now cannot be used
Hi
Any news for solving the problem with chromecast which had been reset?
Hi any news on a solution for those Chromecast 2nd gen that have been factory reseted and still cannot be synced with Google home?
Set your date back on your phone and connect to Chromecast with home app
come si fa ad Imposta nuovamente la data ?
Mon 17th. Still no fix for Chromecast! How long does it take!!?
B7F9
Any update?
Deberían de mandarnos un Chromecast nuevo a todos los afectados, yo si no lo arreglan no voy a comprar otro por supuesto me paso a la competencia, que ya llevan días con los técnicos que se suponen que tienen
Quanto tempo ficará assim? Pq estou sem tv .
Estou no aguardo mais rápido possível
We are eagerly waiting
Have two GCC2 at home. Just reset one of then. The other one is already updated and working. Can't wait for solution The reset one.
Necesito una solución yo restablecí de fabrica y ahora no se puede configurar por favor gracias
Hola Ferjuan23, yo también tuve el mismo inconveniente, lo único que debes hacer es cambiar la fecha y hora manualmente del celular que estés usando para conectarte al Chromecast
Es decir, cambia la fecha a 1 de Marzo de 2025 manualmente en tu celular, luego accede a Google Home y agrega tu Chromecast, este te va permitir acceder a internet y descargar el firmware del error
Ya luego podrás transmitir a tu Chromecast
What happened with chromecast??
We are waiting 10 days!!!
any update if you´ve performed the factory reset on chromecast?
MrWarlox
You just need to change manually the date of the device youre using to connect to Chromecast
Change manually the date of your phone to 1st of March, then go to Google Home and add the Chromecast, follow the steps as usual and after the Chromecast update, you will be able to use the device
Is this done rolling out?
My Chromecast audio remains connected to Wi-Fi (white I dictator light) but not available to cast to.
Do you have any date for roll out the fix its been weeks we are facing the issue
When update will be rolled out? Google taking long time to fix issue. This is second Google product affected this year. Pixel4a mobile due to battery update . My phone was working fine but battery update ruined everything. Now chromcast also suffered glitch. Should we trust Google or opt for other brands?
Set your phone date before 6 of March and connect to your device. It will then update your Chromecast. Remember to set date back again
Hmm how do you reset for cell phone date back?
Anonymous
Not applicable
My device was connected now it says it is offline. What do I do?
Para quem resetou o chromecast qual a solução?
Anonymous
Not applicable
Any news on the fix for those of us who’d already factory reset the device last week? my device is still not connecting working and keen to get this resolved.
Thanks
Anonymous
Not applicable
All fixed!!! Thanks to the user who posted to delete the Google Home App and reinstall - we are back in business!
Any updates? It has been since last Thursday since any new update has been given. Thank you.
I’ve had my Chromecast unplugged. When did you send out the update? I just plugged it back in and I still can’t connect to it. My Chromecast keeps making its own network instead of connecting to my Wi-Fi. What can I do? Should I leave it plugged in and you’re gonna send out another one or do you need to send me directions on how to make it work
Timeline for those who factory reset their devices?
OK, i´m wating for the solution. I Factory reset.
Best regards
Got my factory resetted Chromecast Audio working by setting my phones date to 1st of March and then reconnecting the Chromecast. It got upadated and now it works again. Google's communication is terrible, why won't they just post this procedure to fix your device. Unbeliveable...
Hi. When can we expect to find information on how to fix the issue with Chromecast if we did a factory reset?
I unfortunately did a factory reset before I saw the message of an issue
Los problemas de Chromecast continúan,  que solución tienen para los que lo reiniciamos de fabrica
When are you rolling out solution for those who tried to fix it prior to your admitting there was a problem for 3 days?
So, factory reset.
Si restablecí porfavor pasos a seguir
Проработи.
Айде да няма вече такива изпълнения, че ще ви гази мечка!
