GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,137 REPLIES 16,137
Jenfirststop
Has this also effected Google Nest, Google Display along with the Chrome Casts original links created to Spotify etc? They all went down at the same time in our place. I can now use the Nest and Display again but links are no longer there.
Karen_agh
Y si ya lo restableci?
Pennypanther
What do I do now? I have already factory reset the cast before you advised not to
Emilyjane7738
already factory reset before this communication was published
Taniamahl
Já fiz redefinição de fábrica.
Cm64
GOOD BYE Chromecast HELLO Firedtick
Cm64
Oops
FIRESTICK
Yaritza
Por favor informen cuando todo culpe, hace tres días atrás no tenía problemas de usar mi iPhone con Chromecast sin problema por favor
Eferreiro
Chromecast problem : Don’t you have any procedure to let your community know when there is a major problem instead of being silent for hours and days? I feel that I was not respected as an user.
RaulPTY29
Hasta cuando tengo que esperar yo lo restablecia a configuración  de fabrica
Massimo22
Hola, cuando llegará la actualización?
Sigo sin poder conectarme.
Gracias.
Trump1260
How can I get notified when this is fixed, you have bricked everything in my house that I use daily
Mark40
how long before this **bleep** problem is fixed Are there any qualified techs on the problem??????????
Read the pinned status information at the top of this page. Google started rolling out a firmware update earlier today to fix this.
Desde el 8 de marzo no funciona.
JoaoVitorVga
Não é possível que uma empresa desse porte, não consiga trazer uma solução. Se a ideia é fazer, nos consumidores comprar a última versão, esquece! Tenho que explicar pra uma criança de 5 anos o motivo de não conseguir assistir seus desenhos na sua TV, isso é ridículo!!!
They have come up with a solution. They started rolling out a firmware upgrade earlier today. Read the pinned status information at the top of this page.
AlissonBarbosa
Fiz a restauração de fábrica, não sabia !
Qual o procedimento agora?
Alterei a data do meu celular para antes de 10 de março e reconectei meu Chromecast. Agora é esperar pela correção.
Juliagm
Como se van a contactar conmigo? Desde que medio? Mail?
Fabio2018vicent
Infelizmente já  configurei em modo de fabrica
Josepra
Cuando podré conectarme?
Read the pinned status information at the top of this page. Google started rolling out a firmware update earlier today.
dwally
How much longer now for the repair to be made?? I've factory reset!
Here's the factory reset fix, which you can do now:
https://www.googlenestcommunity.com/t5/Streaming/Regarding-an-issue-with-Chromecast-2nd-gen-and-Chro...
You'll still need to wait for the firmware update from Google for your device to be fully functional again. They just started rolling it out earlier today.
Is factory reset recommended?
Janioribeiro94
Por favor,sou do Brasil e até agora o problema não foi resolvido. Preciso do aparelho pra trabalhar e preciso em casa também.
Jessica20
Hola ya restablecí mi chrome cast, pensé que era una falla de mi internet y lo restablecí. Que prosigue ahí?
Theus_ocd
boa noite!
eu não tive nenhuma informação sobre esse problema de suporte a tempo, e já fiz um reset no meu chromecast. Como vai ficar minha situação agora?
Rob242
Just another suggestion while waiting for the fix. I bought a cheap hdmi cable at dollar store and screen mirrored with my computer to the TV. I can now watch movies on TV. Just a temporary solution but better than watching on computer screen or phone. There's a step by step video on YouTube on how to do it. If you want want to mirror your phone to TV then you will need different cable. Google search it... 😏
Almeisacell
Me ajudem, meu Chromecast não está se conectando e nem  consigo abrir na tv 😔, não consigo assistir meus filmes
Davnan
Can I charge Google as I can't use my Netflix or YouTube subscriptions?
Nhabib
Fix this asap, it's ridiculous that's it's taking that long. Still says on my screen "something went wrong, reset your smart display by unplugging the power cord and plugging it back in"
