GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,122 REPLIES 16,122
Jhig
this announcement is too late when the issues has been going on for day. I did everything to try to resolve this but using advice on the community. INCLUDING factory resenting my 3! Chromecast audios. This is an awful mess
Jayit04
When will you provide the solution for device that has been factory reset?
Ferreiradeah
Eu redefinir meu aparelho, antes mesmo de ficar sabendo da situação. Preciso das orientações para configurá-lo.
Liam14
Any estimate how longer it's gonna take before you all will figure it out? Unfortunately I did factory reset to it.
Raven29
Please provide instructions on how to get it working from factory reset
Set On the phone, set the date to March 1st and reconfigure the device. at least it connects to the wifi waiting for the update with the fix to the problem
Luis152
Ya lo ise como de fabrica
MVerma
I have also done the rest of 2 of my devices, but one is still not reset, pls advise what to be done to make it functional.
のぶ
リセットしないで下さいって英語で書いてあるからわからなかっただろ!
Basalisco
Se lo hai resettato iimposta, sul tuo telefono la data 1 marzo e riconfigura il dispositivo.
kamblesachin
How long are you going to take it has bee five days
RobzillaRock
I don't really care, just that I already had it connected for over a year before I pulled the plug, personal reasons.
kamblesachin
It has been five days how long are you take??
Jasperrr
Factory reset it before coming here and seeing this message 😔 RIP Chromecast see you in a bit bud
Georgerenee
Hi so how do I go about  if I've had a issue  and factory reset  ,what do I do
ValDef
Bonjour,
J'ai réinitialisé mon ChromeCast dès dimanche 9 mars et ce matin, la connexion ne fonctionne toujours pas.... Quand puis-je espérer avoir accès au correctif ?
Merci pour votre réponse
ValDef
Read the pinned status update at the top of this page. Google started rolling out a firmware update fix about 12 hours ago. It may take as long as several days for the update to hit your Chromecast.
Ullis
That's the first thing I do (factory reset)when the Chromecast doesn't work. So I really hope that you'll give us a good help when the issue is solved.
takeyats
I already done factory reset my gen2 chrome cast. Can you  provide how to fix it?
IamRorro
I just came across this issue and I unfortunately factory reset my device. I’ll wait for further resolution.
LilBarbie
I've already factory reset multiple times and am unable to set up my chromecast now.. does that mean it won't be updated now..???
Jeidy
J’ai fait un parametrage usine
Al940723-juli
Verkar som Google har åtgärdat problemet men sen står det att enheter måste vara kopplade för att få uppdateringen! Vilka enheter då?
RATM
I'm afraid we have heard "reset your device" too often, so I expect most of us will have to wait for that issue to resolve as well 🤦‍♀️
Rasecalvarado
Si ya lo restableci de fabrica
