GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,136 REPLIES 16,136
MannyBell
I did that as well, I guess we’re gonna have to wait for an update. Should be able to connect once it gets fixed
Louisa
Hello
What do i do, if I already testa my chromecast??
angelacoramirez
I RESET .
tk64
I have removed my chromecast audio. Will I be able to update when the problem solved?
Twocent
This is absolutely outrageous.  A disgraceful way to run a huge company.
MI028
Eu não sabia e reiniciei.
O que fazer?
Alex777spa
I factory reset my device when it all started and couldn't find any info related to, not even google has it on the web so I venture doing it, I really hope we can have a fix soon cus is really annoying having chromecast not working cus some random issue strikes from nowhere, now am back from work and can't watch anything on tv 😞
Hardik1
Fix it as soon as possible
tk64
I’ve removed and replaced. Will I be able to reconnect and update?
Sieteladri
Pazienza un cazzo
Stefania1985
Io ormai ho ripristinato come funziona ora?
jolxboy
Ya va cumplir una semana y nada, lo que si hice fue reiniciarlo de fabrica y ahora? 😢 Que recomendacion hago?
Robijn
That's a bummer cause via 'help' in the Google Home app,  I had to set it back to factory settings. I hope to get a solution for after having done a reset-to-factory-settings.
Anonymous
Not applicable
Nothing yet ?! Come in it’s taking to long ! Fix that problem ,
Sieteladri
Allora?
BuddMargolis
Thanks!
sirish4u
Unaware of this known issue, anyone would first attempt to do factory reset. Hopefully you will share a solution to this set of victims
Viniciussena
Me enviem o backup, cansado dessa demora !!
Robijn
It doesn't work for me since connecting Chromecast 2nd gen to my perfectly good working wifi. For your solution a wifi connection is needed.
If you've already done a factory reset, this procedure will reconnect your Chromecast to your Wi-Fi network so that it can receive the pending firmware update fix from Google.
https://www.googlenestcommunity.com/t5/Streaming/Regarding-an-issue-with-Chromecast-2nd-gen-and-Chro...
peggy0403
已經恢復原廠設定了
Valhallaman
Demasiado tarde, en las opciones de ayuda ponía si fallaba restaurarlo a valores de fábrica...
Specialized63
This issue with the Chromecast doesn’t matter. Since Trump, I’ve been reviewing all my products and services from the US.
Boaromarques
Não consigo configurar meu Chromecast está com erro . Estou no aguardo de uma solução obrigado .
Anonymous
Not applicable
OMG. You are the biggest tech company on the planet. How is it possibly taking this long? Move your servers or whatever, we don't care. Just hurry the f up.
Mónicabt
Please keep me up date about how to make work my chromecast again. I tried to reset it. Thanks
IamRorro
Español (Yo acabo de realizarlo y si funciono)
Para todos los que SI han hecho Factory Reset / actualización de fábrica:
  1. Temporalmente, ajusten la fecha de tu telefono al 7 de Marzo o una fecha anterior.
  2. Usa la app de Google Home para configurar de nuevo el Chromecast, no podras transmitir aun video o audio pero ya no te dara el error.
  3. Ahora ajusta la fecha de tu telefono a la fecha correcta y espera a que se instale la actualización de firmware de Google.
Supuestamente, se realizará de manera gradual, por lo que podría tardar varios días en llegar a tu dispositivo.
