GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,146 REPLIES 16,146
Blez
Try force stop and delete cache on Home app. Turn wifi and bluetooth off on phone then back on again. Be close to the chromecast. Then Try again. Keep trying until it finds the chromecast.
EdUlloa
Change the date on your mobile to march 7, then reset the device and it will be update. Then continue the standard configuration.
It works
Anonymous
Not applicable
Ok can it be troubleshooting
Éri67
Até quando vamos ter que esperar?!
São milhares de pessoas que fazem uso deste aparelho e estão a diaaas,sem conseguir conexão
Read the status update pinned at the top of this page. Google started rolling out a firmware update fix yesterday.
If you have done a factory reset, then you will need to do this procedure in order to receive the update:
https://www.googlenestcommunity.com/t5/Streaming/Regarding-an-issue-with-Chromecast-2nd-gen-and-Chro
Reprodrigues
My chrome cast still is not working. Can you please assist us asap?
Did you do a factory reset at some point?
Ort
Para los q restablecieron de fabrica el Chrome hagan lo q hice yo, vayan a configuración del celular cambien la fecha de calendario a 8 de marzo y dejen así, luego entren a la app de Home y configuren el Chrome se va a conectar al tv capas le dice q no se puede trasmitir, Pero esperen, yo lo hice anoche y lo deje así pero ya configurado sin desenchufar el aparato la actualización se hace sola al chrome se me acaba de actualizar solo y empezó a funcionar
Huepaz
Pero en en iPhone no se cambia la fecha así de Facil
EdUlloa
Si. Así me funcionó, cambiando la fecha
Adam099
Men we
Ort
Ya se actualizo mi Chromecast 2 gen 🥳🥳🥳 gracias
Va21
O meu tbm deixou de abrir ... O meu primeiro passo foi restaurar.. mais infelizmente sem sucesso.. aguardo soluções..obrigada
Sounds like you did a factory reset. If so, then you need to do this procedure:
Ok that worked for the one I factory reset but the others still aren't working. Should I do the same to them?
Anonymous
Not applicable
Tienes que cambiar la fecha del móvil
Huepaz
En un iPhone? Cómo?
ajsamit
When do you mean by as soon as possible?
Updete
Renato_Forlano
avevo ripristinato a livello do fabbrica il chromecast 2. Poi come qualche gentile collega ha suggerito ho cambiato la data sullo smartphone (impostato 14/2) riprovato a fare collegamento, ha fatto l'aggiornamento ed è ripartito. Grazie a tutti. CIAO
Ciao Renato, avevo rimosso il dispositivo dall'app come tentativo prima di sapere del problema generalizzato. Ora avendo letto ho aggiornato Google home ma continua a non rilevare il Chromecast, tu sapresti dirmi come fare? Grazie
-->>  If you performed a factory reset during your initial troubleshooting, you'll need to do this....
Andoy0000000
My Chromecast just got updated today. I noticed that it’s updated by itself and is now working again after the update was completed. It rebooted after the update and is now 100% working. Hopefully, Google will not make any mistakes again or maybe send a communication first before doing anything. It worries me as I thought the problem was our TV, but it turned out the Google Chromecast firmware was the issue. Nevertheless, it’s now fixed and working.
Wsf
What do we do when we did the factory reset?
Hotrod9974
Yeah good question
dsw_1234
I followed Google's trouble shooting guide when both of my Chromecasts stopped working.  So guess what I did,  A Factory Reset as advised by Google.  Now I receive an email from google pointing to me here, where they tell  me NOT to do a Factory Reset, a bit late perhaps.  It would be nice of them to acknowledge that a lot of users will have done a factory reset already upon their advice, but clearly any admission of fault is beyond them.
If you've already done a factory reset, it's not the end of the world like Google makes it sound. Just do this:
Mauricio64
Vcs podem mandar a instrução no meu email PF, não está funcionando
Mauricio, o meu voltou hoje. Faça o procedimento abaixo:
Repost johnnyzero2
For all the factory reset people who are freaking out and asking "what do I do now?", this procedure will allow you to reconnect your Chromecast to your Wi-Fi network, so that it can receive the firmware update fix that Google started pushing out on 3/13.
1) Temporarily set the date on your smartphone (or tablet) to March 8 or earlier.
2) Use the Google Home app to re-setup your Chromecast. You still won't be able to cast, and the device will be grayed out in the Home app, but that's ok. Also, you can change your phone's date/time setting back to Auto now.
3) Sit back and wait for the firmware update from Google to be installed. This should restore your Chromecast to full functionality.
Deu certo! Obrigada. Genial
Anonymous
Not applicable
ça fonctionne!! merci beaucoup !
How many more days will you require to do or generate a solution for that problem?
If you change the date on your phone to two weeks ago it will allow you to update it. Once updates change your date in your phone back to today’s date. Worked for me 👍
How do you change date? It is set automatically.
Worked here for a factory reseted chromecast. Thank you!
Thank you so much! I’ve been trying for days to get my stuff to hook back up with my account after I did a factory reset on both my chromecasts.  I still can’t stream but this definitely helped set it back up! You are awesome and appreciated 🙏🏽
It’s not possible to change date and time on iPhone. Can we?
Betove
Zowie8888
