GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,134 REPLIES 16,134
Kalmphil
Hi,  when will this be fixed?
Read the status update pinned at the top of this page. Google started rolling out a firmware update fix yesterday, and many users have already received it.
Mdone
Io ho effettuato il reset. Come devo fare per farlo funzionare di nuovo? Provo a collegare il dispositivo, ma non lo trova e appare errore.
Shiftyzdead
What happens if you’ve already done a factory reset (like many others I know that have the same issue)? Is it (to put it blunt) **bleep**ed?
Anonymous
Not applicable
Infelizmente já reconfigurei para configurações originais,  agora indica falha de autenticação,  Aguardo solução
Adriana91
Started working but no sound, anybody with this problem 🤔?
Fredespino
Did a reset on my 2nd gen now cant connect..pls reach out if u have the fix to this.thanks
Playeras93
Información sobre el ekipo Chrome cast
Anonymous
Not applicable
Just received the update for my chromecast Audio. Works like a Charm again. Thanks!
Kelykos
The issue has now be solved for me
Kelykos
The issue has been resolved. 😎
Juang1
Buenas tardes, cuando calculan que podrán resolver el problema? Me suscribí a Netflix y es imposible verlo en la pantalla de un celular.
Juang1
Mi problema es que reinicié a fábrica uno de mis dispositivos y sigue sin funcionar.
Rafael7
Restaurei o meu pra de fábrica pois achei que era um bug AGR não consigo configurar o que faço
mcregge
My Chromecast device has received the update from Google and I am.back in business. It's working fine again.
Bluex
Que esperan para los reseteados? Avisaron TARDE. Defensa al consumidor y abogados tendrán que trabajar
Sammy26
Still waiting and it would have been nice to get the heads up prior to completing a factory reset which seemed like the logical solution! Now that will probably make the issue even worse
BT4
Yes I did factory reset as it was advised in troubleshooting
Lensi90
Mi Chromecast 2da generación ya funcionaaaa! Gracias Google! Yo lo había reseteado de fábrica. Atrasé el horario de mi celu y pude volver a engancharlo al wifi, eso hace dos días. Hoy dejé la tele prendida durante varias hs,, me aparecía el fondo con las fotos y la hora nomas, e iba probando a ver si funcaba, y no, HASTA QUE SIIII. Hagan eso de la hora que funciona!
meer
Thanks a lot Google... for updating the firmware version ... kudos my chrromecast works as normal.... happy watching....
Shahd
I need help to connect with my Chromecast device. I tried everything with lose lees result
Mirthá
No me deja conectar
Markkellychrome
Any update on gen 2 Chromecast fix when it has been factory reset, willing to try anything at this moment.
Bedankt, denk dat dit heeft geholpen. Hoppelijk 👍
joschi03
Thanks for fixing this so quickly, even though you stopped selling it a long time ago. Much appreciated and kudos to the team!
ftrain
One of my gen2’s ccast audio devices came back online last night, the other today. I had not done a factory reset. Whew.
Jotape
No meu caso, uso um Chromecast desses numa TV Sony Bravia meio antiga. Funcionou bem até recentemente, mas, do nada parou. Quando entro no Google Home, ele reconhece o equipamento, mas não o autentica.
Read the pinned status update at the top of this page. Google started rolling at a firmware update fix yesterday. Your Chromecast should receive it soon.
Sugarsmith3
I performed the update to Chromecast however it still does not cast from my iPhone.
Anonymous
Not applicable
Try unplugging it and then plug it back in which will force a reboot and it might work after that just give it a little bit of time.
