Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
03-20-2025 10:49 AM
03-14-2025 03:33 PM
I have reset my Chromecast to factory settings. What now?
03-14-2025 03:35 PM
03-14-2025 03:35 PM
I did that but it doesn’t work
03-14-2025 03:41 PM
I had reset the chromecast to factory settings. Google Home could no longer find the chromecast.
I set my phone to March 8. Then added the chromecast again with Home. The chromecast automatically updated. After the update everything works properly again : )
Set the phone back to the current date.
03-14-2025 03:46 PM
<span;>I had reset the chromecast to factory settings. Google Home could no longer find the chromecast. I set my phone to March 8. Then added the chromecast again with Home. The chromecast automatically updated. After the update everything works properly again : ) Set the phone back to the current date.
03-14-2025 03:34 PM
Cuando y cómo lo van a solucionar???
03-14-2025 03:44 PM - edited 03-14-2025 03:44 PM
Read the status updates pinned at the top of this page. Google started rolling out a firmware update fix yesterday. It may take as long as several days for the update to hit your Chromecast.
If you did a factory reset it and you've been waiting for that specific solution, here's the fix:
https://www.googlenestcommunity.com/t5/Streaming/Regarding-an-issue-with-Chromecast-2nd-gen-and-Chro
03-14-2025 03:39 PM
Quisieran que me informen cuando voy a poder usar mi crohm
03-14-2025 03:46 PM
Read the status updates at the top of this page. Google started rolling out a firmware update fix yesterday. It may take as long as several days for the update to hit your Chromecast.
If you did a factory reset, you'll need to do this procedure to allow your Chromecast to receive the update:
03-14-2025 03:40 PM
To follow your instructions to reset my device I’m unable to use it anymore. I’ve just tried again and it’s not working 😩
03-14-2025 03:41 PM
After I changed the date on my phone to before March 8. I was able to connect my chromecast back on wifi. It's all good and working.
03-14-2025 03:43 PM
por que não presta
03-14-2025 04:41 PM
I am sorry this response is in English but use google translate for this fix offered by johnnyzero2
03-14-2025 03:44 PM
Puse el móvil a fecha anterior al 8 y pude volver a conectar al WiFi.
Después de un par de días conectado al WiFi viendo fotos parece que ha revivido. Supongo que habrá llegado la actualización.
03-14-2025 03:45 PM
You forced me to reset to factory settings!!! Following your instructions and now you’re telling me I shouldn’t I have done so 🤨 leaving me without a solution 🧐
03-14-2025 03:47 PM - edited 03-14-2025 03:50 PM
Nope. Here's the solution:
03-14-2025 03:50 PM
Ours is up and running again. Thanks!
03-14-2025 03:49 PM
Hi, I have a Chromecast (2nd gen). Since the day it failed, my Chromecast hasn't shown any errors. Several TVs have simply stopped recognizing it, displaying a black screen. I haven't reset it to factory settings, and nothing seems to work. I haven't received any updates.
03-14-2025 04:37 PM
Do you have access to the wireless router these devices are connected to?
Is so you can view what date the certificates are valid for via a web browser or router commands if you know the local router ip addresses.
openssl s_client -showcerts -connect <local router ip address>:8443
or use a web browser use the url format
htttps://<<local router ip address>:8443
Then click on the icon to the left of the address bar, you can learn the date of the certificate. You will see
if the valid date is beyond 3/10/2025.
You can learn what your local ip address is by looking into your wireless router and using commands like
arp -D
you can do things like power off a unit do an arp -D then turn the device back on see what address reappears.
03-14-2025 03:50 PM
Hello, I went to identify now that you have this problem and I reset my chromecast, how do I do it now?
03-14-2025 03:52 PM - edited 03-14-2025 03:53 PM
03-14-2025 03:50 PM
I Just update my chromecast and now it's ok, I'm in France . Charge and instal the update in 3 min maxi. 👍
03-14-2025 03:50 PM
Segundo alguns sites, este erro já foi solucionado desde ontem. Por que continuo com problema de acesso?
03-14-2025 03:56 PM
If you did a factory reset as part of your troubleshooting procedures, then you'll need to do this to allow your Chromecast to receive the firmware update fix:
03-14-2025 03:52 PM
Hola gracias pero lamentablemente cuando fallo fue lo primero que hice lo reinicie de
fabrica
03-14-2025 03:57 PM
03-14-2025 04:05 PM
I am sorry this response is in English, but follow this fix:
03-14-2025 03:52 PM
Yo lo configuré de fabrica. Ahora cómo hago?
03-14-2025 04:03 PM
I am sorry this response is in English, but keep you device on while connected to your Wi-fi.
03-14-2025 03:53 PM
Aguardando, até quando?
03-14-2025 04:01 PM
Sorry response is in English but google is pushing out the fix in waves. Make sure your device is online not in factory reset mode. If you did a reset do this fix:
03-14-2025 03:54 PM
Yo reinicie el aparato de fabrica y no puedo entrar ahora que hago?
03-14-2025 03:58 PM
I am sorry this response is in English but keep your unit on your network. The google server's will push out the updates. At least that has been the response in the United States.
03-14-2025 03:59 PM
03-14-2025 03:55 PM
I did a factory reset on one of 3 of our chromecasts. When the update was push to the other 2 I set the date on my iPad to December 24 and was able to recover the one that I factory reset. It then received the update and I can now cast to it……happy days! Hey Google don’t do it again!!
03-14-2025 03:56 PM
Olá, tem previsão de quando esta atualização estará disponível? Neste momento estou impossibilitado de utilizar o aparelho!
03-14-2025 04:02 PM - edited 03-14-2025 04:03 PM
If you did a factory reset as part of your troubleshooting procedure, and your looking for that solution, here it is:
03-14-2025 03:56 PM
Is there any solution for those who have done the reset, recommended in your manual? putty?
03-14-2025 04:00 PM
03-14-2025 03:56 PM
My chromecast and chromecast w/google tv are up and running again. Wish Apple and Samsung would get their act together. AirPod pro 2 and Samsung TV incapable!!!!
