GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,151 REPLIES 16,151
BRIVES
There has never been a problem with Google Chromecast With Tv!
Caemc
After the factory reset we are s#$& ! Maybe if the problem really is a expired certificate they will need to release a update for GoogleHome app to accept invalid certificates, and then we do the setup and afterwards release another version for Google Home app to "solve this created vulnerability"
Factory reset is not the end of the world. Easy fix, just do this:
https://www.googlenestcommunity.com/t5/Streaming/Regarding-an-issue-with-Chromecast-2nd-gen-and-Chro
Roes
Hello, dear Google.
I cannot connect the chromecast to my tv, i tried the app to connect it but it did not work. This happen 4 days ago, it was working but when i try to connect tv it YouTube, it didn’t do anything and it randomly said to get the app. Please help me to find ways it connect it back.
Thank you Google.
caiadop
Sorry, I reset the device. Now I can't synchronised back again. Could you provide the instructions? Thanks
EVB
I have reset my Chromecast to factory settings. And after I have read that someone here had advised to set the date on my smartphone back to March 8th and then go to the Google Home app and select 'pair device.' I did that and sure enough, my Chromecast is working again. So, I don't need to wait for the update from Google."
I just tried this, I can’t believe it worked!
remon1496
My chromecast audio is back alive. 🙂
Renan08
Arrumem logo por favor
Plough
Please resolve this asap
SebR
Even if you performed a factory reset, do the thing with the date change. Go to your phones date in settings. Put March 1st then go to the Google Home app and connect your device. It will connect and do an update. Don’t forget to change the correct date once it’s finished !
SebR
Cleberton
Boa noite, vocês informaram na segunda feira, 10/03, que estavam trabalhando para resolver essa situação. Entretanto, hoje já são 14/03, e até agora nada dessa solução chegar. Teremos que aguardar mais quantos dias?
SebR
Tem uma solução sim. Muda as data do seu celular pro marso primeiro. Depois entra no Google Home e faz a operação de conectar à sua televisão. Isso vai funcionar. Desculpa por meu português ruim
leticiaborges
Nossa, eu já estou com muita raiva disso, sinceramente eu acho uma falta de respeito.
The user orJohnnyZero2 has been trying to push this fix do this fix it's the most straight forward and effective fix
->Do this...
Anonymous
Not applicable
Me llego un mail para seguir los pasos pero no puedo acceder a esta página
Me indican como  hacer por favor?
Manuelar
Hla ee restablecido d fabrica
Analu
Não estou conseguindo acessar meu cromocast
MFF2024
as my Chromecast stopped working I did the factory reset. What should I do now?
Olaf_LC
Now it work
If you have reset it to factory settings like I did, you can do as I did, here it works.
Set the date back to March 1, 2025, before this crash. First turn off automatic date. Reset the device and follow the instructions on the screen. I had also removed the device from the Home app.
When you are done, set the date back to automatic and wait. I waited ½ day, then everything was as usual
ork again...!
Laszlo1
Hi
All my three Chromecast are working again even they has Ben factory reseted thank god.
Thank you for the support
Rjreinwa
When will a fix for my chromecast that was reset be sent to #
amandeepsinghnz
I have done 'reset' already as recommended by your documentation.
So, I appreciate a fix accordingly please.
Any ETA for the fix please?
Felipe5
Quero meu crome de vouta
Julz7
Hi any update when this will be resolved
Read the status updates pinned at the top of this page.
If you did a factory reset and you're waiting for that solution, just do this:
Seemab1
Thanks Google!! Mine Gen2 Chrome cast working fine now..
Gerardje
Still verification problem when you want to setup the device
I'm guessing you did a factory reset as part of your troubleshooting procedure. If so, just do this:
acano
Hello Chrome, I’ve been experiencing this problem for months, and it has caused me too many issues during presentations without being resolved. It connects sometimes when it wants to, and the instructions provided to connect don’t help at all. I’ve already submitted tickets, but no one has reached out.
Anonymous
Not applicable
Waiting, waiting, waiting. More waiting..
When will I be able to use my Chromecast?
Initially I have been adviced to reset to Factory Default.
