GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,146 REPLIES 16,146
taylor27
When is this issue going to fixed? It's about to hit a week. And I use the Chromecast alot and would like for it to be fixed as soon as possible. 😞
  If you performed a factory reset during your initial troubleshooting, you'll need to do this....
https://www.googlenestcommunity.com/t5/Streaming/Regarding-an-issue-with-Chromecast-2nd-gen-and-Chro
Gonzacabj
Reestableci mi Chromecast de fabrica y ahora no lo reconoce, q solución me pueden Dar
-->  If you performed a factory reset during your initial troubleshooting, you'll need to do this....
Trad
Been a while... What's the solution for those of us who have done a factory reset?
Trad
Thank you, I just needed to scroll a bit more. Appreciate that!
Chromchas
Chromchas
Sannevd
I already reset mine before the error, beacaus of a new wifi at home. Is there more known to the setup fix?
**** If you performed a factory reset during your initial troubleshooting, you'll need to do this....
VandradeS
Pessoal encontrei a Solução!
1- Restaure o padrão de Fabrica do ChromeCast
2- Apague os perfil da casa no aplicativo Google Home
3- Volte a data do seu celular para 1 dia antes de começar a falha, no caso desativa a atualização de Hora do seu celular e volte a data para o dia 07/03/2025.
Apos isto configure seu Chromecast como se fosse da primeira vez.
FALHA RESOLVIDA!
Pode voltar a atualização da data automática do seu celular.
In English:
Guys, I found the solution!
1- Restore the ChromeCast to its factory default settings
2- Delete the home profiles in the Google Home app
3- Set your phone's date back to 1 day before the problem started. In this case, disable the time update on your phone and set the date back to 03/07/2025.
After this, set up your Chromecast as if it were the first time.
FAILURE SOLVED!
You can set your phone's automatic date update back.
You should also mention that they'll still have to wait for the firmware update fix to be installed to restore full functionality.
Gufettaowl
So what happens if I already did the reset?
thank you so much. The date passage did it for me. Thank you again
James_Ong
Hi, I saw this alert too late and already factory reset. When can you provide the fix under this circumstance?
Michael_Willian
We've been without Chromecast for almost a week. We need a position on this matter
MárcioFAraujo
Many people reseted the Chromecast. We need that you have a quickly correct this problem.
Check johnnyzero2 posts or mine, this is a working solution.
MonteCristo
Is there any update on how to resolve this issue if factory reset was already done?
Yes. If you performed a factory reset during your initial troubleshooting, you'll need to do this....
Change the date manually on your phone ( before march 9th) to March 7th for example
Relaunch chromecast setup with Google home
It will allow you to reconnecter it to wifi
Wait the hot fix deployment ( performing a power cycle of the Chromecast helps to force the device to get the hot fix quicker)
Macielarlene
 O Meu ainda não voltou a funcionar que faço?????
Nedja
Restaurei o aparelho como faço para voltar a utilizar?
Caromaurelli
Im reset my chromecast, but is not working. Pelase, help me
**  If you performed a factory reset during your initial troubleshooting, you'll need to do this:
mosswilliams12
It’s Sunday 16th March here in Sydney Australia … still waiting for a chrome cast fix, still wondering how Google let this catastrophic failure happen without a Recovery Plan ?
Does Sundar Pichai know what’s happening? LET’S FIND OUT:
Dear Mr Pichai
Google has no recovery plan. So far Chromecast has failed. What’s next?
Hope you can help, roll up your sleeves, find the bugs, fix it 100%, and apologise to loyal customises
Cheers
Moss Williams
SYDNEY AUSTRALIA
Google started rolling at a firmware update fix on Thursday.
However, if you performed a factory reset during your initial troubleshooting, you'll need to do this procedure to be able to receive the update:
Here from Canada is going pretty fast.
In case you factory reset your try the @johnnyzero2 how to here on this chat.
PBAKLP
When it could be fix its already week 10 days but still issue has not yet resolved ????
**Google started rolling at a firmware update fix on Thursday.
Mariel2025
Gracias me gustaría que me avisarán a mi correo por alguna novedad... Lo primero que hice fue reestablecerlo.y hasta el momento no pude hacer q funcionará. Gracias espero su pronta respuesta
Yo tambien! Y ahora resulta que por “culpa nuestra” se tardara mas para arreglar. Puras fallas de parte de la compania
->Google started rolling at a firmware update fix on Thursday.
Anonymous
Not applicable
Thank you so much this helped.
