GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,160 REPLIES 16,160
Read this it might help
->    If you performed a factory reset during your initial troubleshooting, you'll need to do this:
https://www.googlenestcommunity.com/t5/Streaming/Regarding-an-issue-with-Chromecast-2nd-gen-and-Chro
Joetemiew
Hi can you please let us know thanks
-—---- >  If you performed a factory reset during your initial troubleshooting, you'll need to do this:
olizbla
Buenas tardes,
El domingo pasado lo restablecí a valores de fábrica, al desconocer el problema que había.
-> If you performed a factory reset during your initial troubleshooting, you'll need to do this...
Xlaudo
Mensaje en español:
Para aquellos que han restablecido su Chromecast a estado de fábrica y siguen teniendo problemas de autenticación, la solución es muy sencilla: en un iPad o iPhone, cambia la fecha al 7 de marzo de 2025, enciende el televisor con el Chromecast conectado y espera. El dispositivo se actualizará automáticamente sin necesidad de hacer nada más. Luego, procede con la configuración normal y, una vez completada, restaura la fecha correcta en tu dispositivo. Todo vuelve a funcionar perfectamente. Increíble cómo en 7 dias google no propone una solución a esto!
Message in English:
For those who have factory reset their Chromecast and are still facing authentication issues, the solution is very simple: on an iPad or iPhone, change the date to March 7, 2025, turn on the TV with the Chromecast connected, and wait. The device will update automatically without any further action. Then, complete the normal setup process, and once finished, restore the correct date on your device. Everything will work perfectly again.
 terrible inefficiency of Google
Rtmaciano
Olá,  fiz isso ontem à noite, deu certo.
Hoje não funcionou mais.
*** There's actually a bit more to it than simply changing the date on your phone. Detailed instructions here:
Your post is a bit misleading. There's actually a little more to it than simply changing the date on your phone.
KBuya
This is taking forever…. 🫤
-> If you performed a factory reset during your initial troubleshooting, you'll need to do this....
Cleidesobtal
Boa tarde, quando voltará ao normal a configuração? Não consigo conectar pelo amor de Deus!
GSILVA
Set your smartphone's date back to March 7, reconfigure your home (Google Home), and start from scratch. This was a tip from someone in the group, and it worked now.
Retrasa la fecha de tu smartphone al 7 de marzo, reconfigura tu casa (Google Home) y comienza desde cero. Fue un consejo de alguien del grupo y ahora funcionó.
Descargo: Es increíble que una empresa como Google no tenga profesionales capaces de solucionar este problema con una solución tan simple. Si perdiste la paciencia con esta falta de respeto hacia los clientes de Chromecast, no compres otro producto de Google. Compra de la competencia. Boicot es la palabra mágica para una situación tan desagradable.
Retroceda a data do seu smartphone para 7 de março, reconfigure sua casa (Google Home) e comece do zero. Essa foi uma dica de alguém do grupo, e agora funcionou.
Desabafo: É impossível que uma empresa como o Google não tenha profissionais capazes de resolver esse problema com uma solução tão simples. Se você perdeu a paciência com esse desrespeito aos clientes do Chromecast, não compre outro produto do Google. Compre da concorrência. Boicote é a palavrinha mágica para uma situação tão desagradável como esta.
mitesh1984
How to do google firmware update
----->If you performed a factory reset during your initial troubleshooting, you'll need to do this:
Diron
Ok
Silversurfeur
Im waitting for a solving to my issue past 3 weeks...
tarangou
Que hacer si no funciona mi Chrome cast y lo reinicie y ahora no se puede configurar. Ayuda
*****  If you performed a factory reset during your initial troubleshooting, you'll need to do this...
Gbond2
Cambia la fecha de tu dispositivo al 8 de marzo o anterior, intenta conectar el Chromecast nuevamente y realiza la instalación de forma normal. Después de eso, recibirá la actualización automáticamente. Cuando termine, solo pon tu teléfono nuevamente en la fecha actual. Espero que ayude.
PPY
I have been using the Chromecast ( gen 2) for many years. Can you explain what happened and how long to fix?
Talice
Mine is reseted.
-> If you performed a factory reset during your initial troubleshooting, you'll need to do this.....
Brinabolck
Boa , tarde, já redefinir para os padrões de fábrica, como fazer nesse caso?
->>>> If you performed a factory reset during your initial troubleshooting, you'll need to do this:
Mono-2025
When we can use it again
DANI0606
Por favor corrija isso, infelizmente fiz a restauração antes de olhar a mensagem, pq vocês não avisaram nada.
pz25681gmail
Hi
It has been 3 days when unable to connect with chrome cast, when I can expect solution.
Rgds
Purushottam
8147214097
johnnyzero2
For all the people who performed a factory reset during their initial troubleshooting, this procedure will allow you to reconnect your Chromecast to your Wi-Fi network, so that it can receive the firmware update fix that Google started rolling out on 3/13.
1) Temporarily set the date on your smartphone (or tablet) to March 7, 2025 or earlier. If you don't know how to do that, see below.*
2) Use the Google Home app to re-setup your Chromecast by adding it as a new device (+). You still won't be able to cast, and the device will be grayed out in the Home app, but that's ok. Most importantly, it'll now be reconnected to your Wi-Fi network so that it can receive the firmware update fix.
3) Change your phone's date/time setting back to Auto now.
4) Sit back and wait for the firmware update from Google to be installed. This should restore your Chromecast to full functionality.
Note: Supposedly it's being done as a "phased rollout", so it could take a while for the firmware update to hit your Chromecast. Also, some have reported that power-cycling your Chromecast (unplug/re-plug the power cable) will sort of "provoke" the firmware update to be installed. Patience.
*How to change your phone's date/time settings:
For iPhone/iPad: go to Settings, General, Date & Time. Disable "Auto" and manually set the date to March 7, 2025 or earlier.
For most Android phones/tablets: Settings, General Management, Date and Time. Disable "Auto" and manually set the date to March 7, 2025 or earlier.
****Google REALLY should pin this information to the top of this support page!!!****
faizanusmani
How long you will take to fix this issue, most of them have done factory reset.
we need a approximate date or week number to resolve this issue.
Amol04
Can someone help me as i have done factory rest already.
Gbond2
Change your device date for 8th March or previous, try to connect Chromecast again, do the installation normally.
After that, it will get the update by itself. When finish, just put your phone back to the actual date. Hope it helps.
