Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
03-20-2025 10:49 AM
03-20-2025 08:08 AM
How much longer do we have to wait? This is so frustrating!!
03-20-2025 10:11 AM
Bonjour, je viens de télécharger la nouvelle version de google home mais quand je tente de me connecter, soit on m'indique que je ne peux pas me connecter, soit que le micrologiciel du Chromecast n'est plus à jour
03-20-2025 02:12 PM
It does work for YouTube and Mac, but it doesn’t for Netflix or Prime after the update.
03-17-2025 12:10 PM
I need a help because I reset my device! How can I do?????
03-17-2025 12:13 PM
They've just posted we will need to update the Google Home app in the next days as soon as the update is available
03-17-2025 02:35 PM
To fix the problem if you factory reset your Chromecast, the solution is:
03-18-2025 11:43 PM
Changef date to 19 feb 2025
Hoe Home will open .
But cannot connect even pressing the settings butten
03-18-2025 11:45 PM
... when pressing.
It still Works with all nu other devices such as lights and Sonoff switches
03-17-2025 12:16 PM
For everyone who has used the factory reset, the solution is very simple. Put your phone on a date like 7th of march. Do the setup agian, and it will get the update fix you need. Afterwards you can put the date back to today.
03-17-2025 12:53 PM
dont work for all devices Chromecast Audio!
03-17-2025 11:09 PM
Thank you it works if only I knew this 2 weeks ago
03-17-2025 12:19 PM
When will this be resolved? We rely on our Chromecast to watch all of our TVs!
03-17-2025 12:29 PM
Olá qual a.previsao do reparo, inadmissível, já estou a 10 dias sem conseguir usar minha Tv
03-17-2025 12:35 PM
Bonjour,
Avez vous une solution pour les personnes qui on procéder à la réinitialisation d’usine svp ?
cordialement,
Mme Fournier
03-17-2025 12:46 PM
I reset before I saw this message. Can you help get me back du standard settings?
03-17-2025 01:40 PM
Set your phone's date to March 3, 2025, then set it up again with the Google Home app.
03-17-2025 12:46 PM
¿Cuándo tendremos respuesta?
03-17-2025 12:46 PM
Hola, gracias a su equipo por su trabajo al reparar este problema, desgraciadamente en los mismos pasos para el problema daban como solución restablecer a fábrica el producto
03-17-2025 12:49 PM
Do you speak english? I dont understand
03-17-2025 01:18 PM
Simply copy-paste in Google translate. But does not repair the problem.
03-17-2025 12:49 PM
Do you have an update on when the instructions for those of us who done a factory reset will be available?
03-17-2025 01:01 PM
I had done factory reset. Chrome cast is not working . How long should I wait before discarding it and buy an alternative to Google chrome cast?
03-17-2025 01:03 PM
Quando é que isso vai acontecer?
03-17-2025 01:13 PM
Bom
03-17-2025 01:11 PM
It's been a week now, do you have things fixed?
03-17-2025 01:22 PM
I had reset the chromecast to factory settings as well. Changing phone date back to 1-March did the trick in setting up. The device updated automatically and restarted. Afterwards everthing worked again and setted date back on phone.
03-17-2025 01:51 PM
Hoe zet je je telefoon terug op 1 maart
03-17-2025 01:44 PM
He restablecido de fábrica y no hay manera que pueda conectar
03-17-2025 01:42 PM
Eu restaurei o meu e agora,não pega
03-17-2025 03:37 PM
Me deram a seguinte solução.
1-Muda a data de seu Smartphone para 01/03/2025.
2- Depois reseta o Chromecast.
3- Entra no Google Home e insere novo dispositivo.
4- Após achar o Chromecast retorne a data automática do seu Smartphone.
03-17-2025 01:46 PM
Olá
03-17-2025 01:48 PM
Wanneer wordt het opgelost
03-17-2025 01:49 PM
Gostaria de receber o backup
03-17-2025 01:49 PM
Preciso das instruções de atualização do Chromecast
03-17-2025 03:36 PM
03-17-2025 01:53 PM
Porfa. Espero pronto una solución para chromecast de 2°generación estoy sin poder ver tv.
03-17-2025 02:39 PM
cambia la fecha del celular que uses para conectarte al 6 de marzo e intentá conectarte.
03-17-2025 03:29 PM
Perfeito. Foi resolvido. Obrigado
03-17-2025 01:56 PM
Good...
03-17-2025 01:59 PM
Ya ha pasado una semana y seguimos esperando... Deberían sustituir los dispositivos que no funcionan
